Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
F231 problem I changed the fuse in my television, and it worked perfectly...for 2 days! I have the same red and green shadowing and powing on my television again.Is there a reason the fuse could be blowing?
    Genius:
  • 1,030 Answers
Did you resolder the flyback connections.. I have found the reason this fuse blows is bad solder connection around flyback. Consult the fl231 problem under tips and tricks under willtab profile
Posted on Nov 17, 2008
  • 88 Answers
NO SIR
In this fault fuse dosen"t blow further
any way you replaceFuse by same (oldone)Rating.
for shading proble
clean inside RED/GREEN/BLUE/ CARTHODE RAY UNIT BY SOFT CLOTH (DO NOT USE ANY SOLUTION"S)
AFTER THAT YOU GOT A GOOD QUALITY PICTURE.
OK
WISH YOUALL THE BEST.
Posted on Nov 16, 2008
I have a sony kp-51ws510 projection tv, i replaced the convergence ic's and a pico fuse and then reset the convergence. The tv looks good except for a green shadow on lettering, also on the convergence...
Did you check the two pico fuses on the G board? Usually at least one will blow when the original ICs failed. I am attaching a pic that shows the 2 pico fuses on the G board.
Jul 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Red, Green, and Blue shadowed lights
the lense red blue green is warped you will need to replace those lenses
Aug 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
Tried to replace fuse f231
My first suggestion on this set is to cheack to make sure you have not loosen the cable connections between the boards there is a flat ribbion cabel that runs from the green main board to the front crt boards. when tiltling the cuircit board this can come loose.
Jan 09, 2009 | RCA R56WH76 Projection Television
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Blurry screen replacing f231 fuse link
i have the same problem does anyone have a solution????
Jun 09, 2008 | RCA R52WM24 52" HDTV Projection Television
Location of convergence IC's in R52WM24
i have the same problem where is the fusible link i replace 2 boards and a connector (t.v. repair man can and diagnoised the problem but did not fix it)
Feb 02, 2008 | RCA R52WM24 52" HDTV Projection Television
I have three
I had the same problem. Thanks to the many posts on this site I was able to deduct that it was the Fusible Link F231. (See other posts about convergence problems) Was able to purchase them at mouser.com. Part# 576-3960400000 Littelfuse Fuses - A 125V UL TL LL .400A . They are only 55 cents plus shipping. I bought 5 for under $10 shipped. Only took 2 days to get them. Replaced it (needs to be re-soldered to board) and TV works like a charm!! I couldn't believe it. What a lifesaver!! Now I'm set if the fuse goes again...
Good Luck!
Jan 01, 2008 | RCA R52WM24 52" HDTV Projection Television
Red & green lines
Sounds like you have hardware failure in the convergence circuit. Some combination of the IC's, fuses, and/or resistors has failed. Repair cost is $250-$400 parts & labor
Dec 02, 2007 | Akai PTH5498 54" Rear Projection...
Has a shadow on picture. Red, Green is not alligned
You need to set your convergence. Check your owner's manual on how to do it. I'm not sure the exact procedure on that model, but usually you can find it in the setup menu of the tv. What you're trying to do is line the red and the blue up perfectly with the green so that they all blend together to give you one picture.
Oct 20, 2007 | Hitachi 61UWX10B 61" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
