Question about GE WSXH208A Front Load Washer
Press-Grip Clasp I was wondering, if I need some kind of special tool to take it out or can I just use a pliers, and how would I have it wrap back?...Use a pliers again to put it back. Or would I have to buy another one after I take it out.
  • jayme_leigh Dec 02, 2008
    what size of pliers did you use? i keep trying and it keeps slipping
I just pressed the green clamps with pliers (which was a bit tricky to get the pliers just right and wedged inside the washer), but it works. Then before putting the black ribber piece back in, slide the green clamps back on, a bit further back on the rubber than they need to be. Then push the connections of the black rubber piece back on and finally use the pliers to move the clamps back up into place. Hope this helps!
Posted on Nov 17, 2008
How do I align the camshaft to the crank without placing cam locking tools on it before replacing
I have often used vice grip pliers on non machined surface of cams wrapped in a rag to carefully turn cams to correct position. This should only involve slight adjustment if everything was lined up when you took the old belt off. IF NOT, or old belt had broken, you need to know if your engine is an "interference" or "non-interference" engine before you go further.
Dec 19, 2014 | Cars & Trucks
Kennith cole reaction watch
try to change your settings of your clock by getting it full circle to get back to real time and see what happens. if still problem persist then you might send it to repair service or it should have warranty service for an expensive watch. hope that helps!
CHARCOIS
Oct 01, 2008 | Watches
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 | Watches
My dh9118 needs the bottom blades flipped but i can't take out the screw for the shaft,
It's been a while, but i believe i remember reading that some of the blades were held by screws that were turned clockwise to loosen.
Or were you having trouble getting the screwdriver to fit in the head of the screw?
Sep 25, 2017 | Toys
How do i adjust the band on the slimline mesh skagen watch
Step 1. On the reverse of the strap you should see a succession of ridges. You will also notice a corresponding ridge on the clasp. Sounds obvious, but once you have decided where the clasp should reside on the strap, you need to align these two ridges.
The reverse of the strap
Step 2. Get a piece of string or ribbon and wrap it around your wrist. Snip the string so that one end meets the other and measure this diameter.
Step 3. On the other end of the strap you will see the hook which goes over the clasp - you will see the next picture. From this hook the measured distance will be where the end of the string lies.
The clasp mechanism - the watch is to the right of the picture
Step 4. This is the tricky bit! Insert a small screwdriver into the hole on the main clasp part, from the right hand side and bend it down towards the strap thus opening the clasp. Do not insert a tool from the left side, under the clasp and use the bar as a fulcrum; you will bend this rod and the watch strap will not hook over it. Move the clasp to the desired position and gently locate the ridge nearest the position. Once located, press down on the open clasp until it clicks into place - voila!
Related posts:
Dec 26, 2012 | Skagen Slimline Mesh 358SGS Wrist Watch
Where exaxtly is the oil pressure switch above the oil filter adapter.on a 93 k1500 blazer with a 350 , are any special tools needed ?
You might try a search on youtube for a video - if the switch is not above the oil filter it may be at the back of the intake manifold on top of the engine. They make a special socket for removal or you may be able to use vise-grip pliers.
Dec 04, 2012 | Cars & Trucks
How do I put the back of the wrist watch on.
You probably need to go to a watch repair professional. Any business that replaces watch batteries should be able to help you. They have a special press designed to support the watch safely while they snap the back onto the case. This sometimes takes quie a bit of force and rqeuires that the watch case and back plate be perfectly aligned.
Sep 29, 2009 | Timex 1440 Nylon watch
Fuel filter wont come off.
usually there is a special tool to remove those clips... if you live in the states i believe autozone will rent/loan you the tool.... if in canada you can rent/borrow the tool from canadian tire. if you cut the clasps i doubt you will be further ahead as you would need the tool to install the new filter.
Sep 02, 2009 | 2002 Oldsmobile Alero
How to compress rear brake caliper on 2002 toyota mr2
There should be 2 slots in caliper piston,Take needle nose pliers and insert one tip into each slot,will have pliers in open position.spray lube on rubber seal,then twist pliers in clockwise direction.Piston will screw in.You can also buy special tool for this.
Jun 20, 2009 | 2002 Toyota MR2 Spyder
How to adjust the watch strap
I just bought the o-ring watch by Starck, and it looks to have the same style of strap. If you look on the side of the clasp, you will see a pin on both ends. You have to remove these retention pins first (which may require tools that are unavailable to you). First, stabilize the watch on its side on a soft mat - I used the back of a mouse pad. Then, use a thin, stiff piece of metal tool to push the pins out slightly. I used a crafting tool. Once the pin sticks out enough, you can use a fine set of pliers to pull them the rest of the way out. (If this does not make much sense at this point, you may be best off going to watch shop.) Once you remove the pins, the clasp can be removed from the strap simply by lifting the clamp. You then trim the strap with a pair of sharp scissors to the appropriate length - make sure you see exactly what the end looks like, because the shortened strap will need to have the same apperance. After trimming, reclamp the clasp onto the strap, and reinsert the pin. You may need a small hammer to get the pins seated completely. Then, you're done. So obviously intuitive, why would anyone need directions, right? Honestly, Fossil did not make this one easy at all. Kind of irritating.
May 15, 2008 | Fossil PH1057 Wrist Watch
GE WSXH208A Front Load Washer Logo
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
