Question about Poulan Pro Chain Saw 46cc 20"
Poulan Wood Shark Chainsaw - wood smoking. Is chain on backwards?
I just finished cleaning my chainsaw - took off the cover and then put it all back together. I started cutting some decayed red wood fence that we are replacing. The saw was not cutting through it very well. Is my chain old? Do I have the chain on backwards, which I don't think is the case, but I can not find a picture anywhere. Please help. Thanks.
  • willyr Nov 16, 2008
    Is there a site on line for directions on how to clean the air filter? I am pretty handy for following directions, but unfortunately I lost the paperwork for this machine. Thanks so much for your help.
  • 14 Answers
I cannot tell you about a picture, but for one: chain direction, the bottom of the bar is where the cutting takes place, and therefore, looking at the chain, you will see, on the bottom, the antikick back link is sort of curved, and then the next part is the straight tooth. The highest part of this straight tooth is the sharp edge, and this high part should face towards the motor. The chain, on the bottom side of the bar, is pulled in towards the motor by the clutch/gear. That is your direction of travel.
As to cleaning the air filter, Hopefully you have access to compressed air, as in simply blowing off the dirt. You do not want to use liquid cleaner. Simply blow off any dirt, after pulling the filter away from the carburetor, of course. Then place it back in place.
It may be that your chain is real dull. The top edge of the high part of the flat tooth needs to be sharp. And the outside corner needs to come to a nice point. Remember, there is two cutting surfaces on each tooth, the top is cutting down into the wood, and also that outside sharp corner is openning the cut for the bar to pass through. Proper sharpening, if new to it, can be hard to grasp. Any chainsaw manual should show how to do a good job.
Posted on Nov 19, 2008
  • Gordon Deisting Sep 29, 2014
    I found a picture on how the chain is suppose to go,which is on the cover that covers the chain.It show the the proper direction the chain is t go.
Your chain may need to be sharpened or replaced. However if it feels like the saw just doesn't have enough power to cut the wood you probably need to clean the air filter.
Posted on Nov 16, 2008
  • drunyboy22 Nov 17, 2008
    There are not instuctions online. They are in the manual. However they are fairly easy. You just take the air filter off and wash it in hot soapy water. After washing it you let it air dry. Then re attach to your saw. Hope this works for you!
    I'm sorry about what I typed last night. I did find a way to download a new manual from the internet. You can do this by going to the Poulan website. In the manual it tells you how to wash the air filter.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
I feel stupid I was doing some work for the neighbour I am also a mechanic and an experienced person with my chainsaw I have not made a mistake like this for a while In my case I flipped the bar upside down this made the chain which was brand new stop cutting wow what an idiot I looked at it and eventually figured it out the words were upside down my clue always remember the bar is directional the arrows point the direction of the rotation and the sharp edge is traveling away from the saw on the top and towards the saw on bottom
Posted on Apr 13, 2013
Mt999 chainsaw. Brand new. Not cutting through wood although blade rotating. Just seems to be burning wood.
If it's all brand new, then sounds like you have the chain on backwards. The angled parts of the cutters should face forward while on the top of the bar.
Mar 16, 2014 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Chain turns but comes loose and burns at wood. also get alot of smoke from chain area
Insufficent chain oil to the bar, check there is oil in the oil tank, remove the bar and clean out the delivery hole in the bar.
Jun 15, 2011 | Poulan 14" Chainsaw
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
Poulan wood shark 1950 wont start spark plug has
Try to squirt a little gas in the carb and see if it pops or tries to run for a short time. The diaphram in the carb is probably old and hard. That would be the first place I would look.
Nov 07, 2009 | Garden
Poulan Wood Shark 1975 14" /35cm after resetting the spring the chain will not turn what to do
Clarification Request
Posted by longhorn294 on Jun 07, 2009
Are you sure you reset the brake?
Remove the starter cover, does it rotate when pulled? If yes reinstall it.
Pull the chain brake fully aft, does the saw rotate? If yes your problem is solved. If no did you put oil in the gas before you put it in the tank? If yes or no elevate this to your friendly neighborhood chainsaw seller/mechanic. HTH
Lou
Jun 07, 2009 | Poulan Garden
Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How can I put my chain brake back on?
tye going to psep.biz and looking at a breakdown for this saw. make sure you have the exact model and type number and their breakdowns are excellent. Let me know if this doesnt work
Feb 14, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 210 Pro not oiling chain
Make sure the oil port doesn't have a chip of wood blocking it.
Jan 30, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
4,200 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
