Question about Euro-Pro Shark SC-505 Handheld Steam Vacuum
Can't get the top unscrewed
The steamer has been stored in attack for summer. The top will not unsrew. Have tried using pliers and it is stuck. Any tips?
  • 5 more comments
  • karenmattio Dec 01, 2008
    how can u get it off
  • Anonymous Jan 02, 2009
    I can't get the top off also.
  • Anonymous Jan 18, 2009
    I have the same problem, what do I do about it. Let me know
  • Anonymous Feb 14, 2009
    I have the same problem and unfortunately only used the cleaner once. The cap will not unscrew. We have tried everything and it sounds like I'm not only. Not sure if there are two different metals and they fused together?
  • Anonymous Feb 23, 2009
    I have the Euro Pro hand held steamer. I could not get the cap off even with a wrench. My son was able to get the cap off by braking the plastic. What had happened is the two metals corroded to each other. I am not able to find any place were you can just order the cap.
  • Anonymous Apr 24, 2009
    We are having the same problem.
  • avyluz May 12, 2009
    hi i have shark sc 505 steamer, i cant open the lid. it got stock how can i loosen it
My sister gave me hers that was stored in a humid storage unit--it still had water in it. What I did was hold down the pressure release trigger (with my leg against table top) then turned the top off with both hands, it wouldn't budge till I held the trigger(black). hope this helps, I am also looking for a manual for this little power house. so far I like it.
good luck.
Posted on Jul 19, 2009
I had same problem, the brass threaded cap corrodes in the threads on the steamer making it impossible to unscrew. Mine had no water in it at the time, so I plugged it in until it heated up and was able to unscrew it with large channel locks. Be careful not to break the plastic cap. Do not leave plugged in for long, takes only a minute to heat it up to try unscrewing
Posted on Jul 18, 2009
I had the same problem. Mine had been stored for a year. We had to completely destroy the plastic cap. Once down to the metal underneath we did the boiling water thing. It didn't work at first so we tried it again. And then immediately after applying the boiling water we used ice water to make the metal contract. With pliers on the neck and pliers on the lid we were able to open it. But, I know my husband had to put some strength into it. Hope this helps you all!!!
sorcha1580
Posted on Mar 28, 2009
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Why is vax s7-a+steam mop steamer dripping water and cuts on and off
I managed to fix mine after a little effort. It was blocked well up in the nozzle into a small pinhole where the steam comes out of the 'small kettle' in the steam mop.
To fix:
  • take the blue side bit off by unscrewing the two small screws
  • Undo the screws inside (there are about 11)
  • Once these were undone there was two screws holding the nozzle cover.
  • After unscrewing these pull the nozzle cover of and scrape limescale from inside the small hole where the steam comes out
  • Put it all back together and it should work much better
You should only really do this if you are competent as there are lots of wires etc. and if your steam mop is not covered under warranty as messing around with it will void this.
Hope this helps :)
Jul 04, 2014 | VAX Appliances Vacuums
How do I get a stuck top off a Scunci ss1000 steamer?
try putting it in a freezer for awhile cold makes metal shrink and that may loosen the top .
Dec 07, 2017 | Scunci Ss1000 Steamer Irons/Steamers
I bought a rubbermaid reveal mopping system.and I dropped the mop while using and the bottle fell out, the cleaning solution gurgled all over the floor, and now the cap is stuck inside the mop. Can anybody...
Try using a pair of needle nosed pliers, in reverse. Put the tips into the cap and SPREAD the handles. The jaws MIGHT provide enough grab to back the cap out. Otherwise, it will be a try this and try that job. No two are ever alike.
Jan 18, 2013 | Rubbermaid Reveal Spray Mop Kit,...
How do I get an adapter for the faucet for my Bissell 1631 Power Steamer. The brass fitting on the end of the water hose does not fit the faucet. I need one that I can add to the current brass fitting so...
I went to OSH hardware. I unscrewed and took the portion of the faucet- that the hose from the steam cleaner was to fit into and I took the hose right into the store. I just bought my unit at the thrift store. Works great. I love it!
Jun 27, 2011 | Bissell 1631 PowerSteamer ProHeat Canister...
I have the scunci 1000 steamer- it was sitting for a while and the cap on the top looks like its corroded and i cannot remove it from the steamer - i just bought it a year ago, but i think the salt or...
Hi, Elaine, W/D here.
Corroded items are difficult to break loose as the corrosion builds up a layer that binds the parts together. Try this, as I usually have good luck with this method:
Tap around the perimeter of the cap with a wooden hammer (like a meat hammer). Don't hit it too hard, you don't want to hit it like you're driving a nail, but somewhat softer. Then, try wiggling the cap open then closed. Once it breaks loose a bit, you'll find that it will move only so far, and then bind up again as the corrosion gets to a built up point. Back and forth, tap,tap, tap, back and forth....etc. You'll get the cap open a little more with each cycle, then it will finally open.
Best regards, --W/D--
Apr 01, 2011 | Scunci SS1000 Handheld Steam Cleaner
Cant get the top off
you must put steamer on a flat surface and prees down as you unscrew cap
Oct 06, 2010 | Euro-Pro Shark SC-505 Handheld Steam...
I need replacement parts for my Scunci SS-1000 Steamer
hi i need this part for my scunci steamer model ss-1000 this is internal parts inf to dannacielcr@hotmail.com thanks
Jun 04, 2010 | Scunci SS1000 Handheld Steam Cleaner
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Euro-Pro Shark SC-505 Handheld Steam Vacuum Logo
1,035 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
