Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
Shark Steam mop won't steam
The unit heats up but produces no steam. This is the second one it happened too. I returned the first one and now the second one doesn't work
  • 4 more comments
  • Anonymous Nov 30, 2008
    I've got the same problem. I've never used the unit before either.
  • dctahan Dec 04, 2008
    Same damn thing...heats up - but nothing else...no steam at all
    Second one I bought with the exact same results.....
  • Anonymous Mar 21, 2009
    worked for a while and this morning - heat but no steam.
  • Miss GB Apr 06, 2009
    Worked fine for three months and suddenly stopped producing steam. I thought it was great up until this point.
  • Joyce Roberts
    Joyce Roberts Nov 29, 2013
    Use half water and half vinegar and it should correct the problem.
  • Joyce Roberts
    Use half water and half vinegar and this will take care of the problem.
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zsd
Posted on Sep 24, 2010
This was an easy fix, actually. Take off the mop attachment and you'll see a little hole where the water/steam comes out. Use a toothpick and clean out that hole and it'll work good as new. NOTE: Be careful! I cleaned it while my unit was still warm and once the hole was clean, steam shot out and burned the s*&% out of me. I have a bad burn on my shoulder. Either wait until the unit is cold or makes sure you work from the side and wear goggles.
Posted on Mar 26, 2012
SOURCE: My shark steam mop heats up but won't steam. help
My problem was in the mop head itself where flexible tubing meets the plastic. I took out the 4 screws that connect the swivel mechanism, then the two that hold the flexible tube in place. Once that was free I could get a large straightened paper clip in the hole to break out the clog of mineral deposits.
Posted on Jun 21, 2011
evbob
  • 8 Answers
SOURCE: shark steam mop
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
Posted on Jun 13, 2009
heatman101
  • 43501 Answers
heatman101
ab
heatman101
  • 43501 Answers
SOURCE: No steam coming out of my shark mop.
heatman101
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Posted on Feb 06, 2009
Water is heating but the mop is not producing steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Dec 30, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
heatman101
;a
Jul 31, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam
heatman101
May 25, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop will not heat up and produce steam. it has only been used 4 times. help
Empty the water and try different water...
heatman101
Jan 18, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Cleaner heats up but no steam is coming out. It let loose a big ball of steam when I plugged it in, then nothing and still won't heat up enough to produce steam.
heatman101
nt
Nov 02, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop model #S3202 is no longer heating and producing steam
The heating element may have died or there is an obstruction...
heatman101
Jul 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
heatman101
ab
May 29, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
heatman101
vvb
Mar 31, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Turns on but won't produce steam
heatman101
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
13,852 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
