Question about LaCie 1 TB 2big Spare Drive 301307 SATA Hard Drive
Playstation wont detect my hard drive
I just bought a Lacie Gold hard drive.
I reformatted it from FAT32 to NTFS so it would work better with my laptop whichis Windows XP SP2.
Now however, my playstation 3 cant detect it- Ive found out PS3 orks also in FAT32!!
How can I reformat back to FAT32? My laptop only seems to allow me to format in NTFS- is there a download available?
thank you
  • 33 Answers
SOURCE: deleted 4 folders for lacie silverscreen 500gb
Dead easy, simply attached the SScreen to your PC/Mac and create the four folders:
"Movies"
"Pictures"
"Firmware"
"Music"
It requires these four folders to boot the OS!
--No Quotes in folder names--
Cheers
Posted on Sep 12, 2008
  • 13433 Answers
SOURCE: Cross platform backup drive format/partition
Fat 32 is the only system that would work on all 3 os's direcly.
You could use NTFS if you only write those big files on windows, you could read it on both linux and mac.
NTFS 250 (or ext2)
HFS 120
If you need to use the last partition on of the operating systems the fat 32 would work here, but as you know the problem with that. Looking at the wikipedia page ext2 would also work.
Posted on Jan 27, 2009
  • 10 Answers
SOURCE: ps3 does not reconize FAT32 partition on external hd
download this program http://www.compuapps.com/Download/swissknife/swissknife.htm
and format it again then try it, it should work fine, did for me.
Posted on May 31, 2009
SOURCE: I immediately reformatted my LaCie
I had exactly the same problem with my Lacie Rikiki Go USB 2.0 Portable Hard Drive. I formatted it before runing the setup assistance software and now it shows only 10 MB capacity. I think the solution would be to download the setup assistance from somewhere and run it but I couldn't find it anywhere in the web.
Is there any other solution?
Posted on Jan 09, 2011
  • 86 Answers
Reformat again. Be sure you do a full reformat in NTFS. Select the default Allocation Size
Posted on Mar 12, 2011
Mac problems
Hi Jay
Check the formatting of the lacie. Macs can read and write Windows formatted drives except those formatted in NTFS, which they can only read.
If you can read the drive, the chances are it's an NTFS formatted drive.
If you need to use it on both systems then you had better reformat it with the FAT format.
Jun 04, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
Lacie extern. hard drive is recognized, but I can't access files
Try connecting the Lacie to another computer, if it doesn't work then the hard disk may need to be formatted using Disk Manager. I suggest you format as a primary partition in FAT32.
If it doesn't work then it is possible that the hard drive in the Lacie has failed.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32
There are companies that can recover data from faulty hard drives BUT it will cost you an arm and a leg for their services.
Sep 12, 2009 | LaCie F.A. Porsche (301177) Hard Drive
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Hope this helps you out.
Jul 15, 2009 | Western Digital My Book Essential Edition...
How to i reformat a lacie 500gig external hdd
The Mac OS can't natively write to NTFS (it can write to FAT32 however). But if you install MacFuse followed by NTFS 3-G on OS X then you'll be able to write to your NTFS drive.
Oct 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
My pc can't see the lacie hard drive
remove and return it again to the usb port? or maybe your enclosure has a problem?
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Drive Full After Backing-Up Just Under 4gb of Files
Are you trying to create one giant zip file or something similar? It sounds as if your Lacie 250gb hard drive has been formatted with a FAT32 filesystem and you are running into the maximum file size limit of 4gb minus 1 byte. Try just copying your files without using any compression utility or try reformatting your Lacie 250gb hard drive with the NTFS filesystem instead.
Feb 07, 2008 | LaCie (300728U) 250 GB Hard Drive
Drive Shredded
Open Administrative tools, Computer management applet; under storage, disk management. You will probably need to partition and reformat. If this drive is used only on XP machines, then format NTFS, otherwise FAT32.
Sep 18, 2007 | LaCie (300740) 160 GB Hard Drive
LaCie 1 TB 2big Spare Drive 301307 SATA Hard Drive Logo
155 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
