Black line on the left side of the screen about one fourth out. model # 42 EDT 41 A can you fix this by teling me how? I blew it out with my air compressor as a store told me and nothing helped?
  • 3 more comments
  • dogs361 Nov 16, 2008
    Did the suggested things and it did not go away. Any more suggestions?
    Did all suggestions and no change in the black line. HELP!
    What Do I try next?????
    The tv is a Hatachi and the model # 42EDT 41 A purchased in 2005.
    The repair shop in Boise said he had never seen a black line problem like ours. However, we will check on finding another.
    Thank you your service I would say was normal.
  • 4,472 Answers
First off I need the make and model of the television. Secondly it definitely sounds like an internal problem that should be serviced by a professional. Once I have more information from you I can assist you further.
Thanks,
lee
Posted on Nov 16, 2008
  • Lee A.
    Lee A. Nov 16, 2008
    Unless you have a lot of electronic expertise I would recommend contacting the nearest hitachi service center and you can get an estimate as your tv is in need of professional service. You can locate the nearest one at this link
    http://www.hitachi.us/Apps/ServiceLocato...
    Please take a moment to accept and rate my solution accordingly. If you have any further questions I will be more then happy to assist you.
    Thanks,
    Lee
  • 728 Answers
Check all of your connections to the projection tv to make sure they are in firmly. Then try using a different video input and see if the line is still there. It should go away.
    Scholar:
  • 181 Answers
First unplug the tv for sometime then replug and see.
  • fixyy Nov 16, 2008
    if still the line remains its due to the board error,
    you have to check out on the main power supply board of your tv as some capacitors or ICs may have become loose or have blown out and needs replacement.
Left headlight replaced but still not working, swapped with right bulb so bulb is good
If you checked for power inside the socket(power and ground) the bend the tabs in the socket to touch the bulb wires. They get hot and bend. pull them out a bit.
May 19, 2015 | 2008 Hummer H3 Alpha
VIZIO 42" tv has thick black vertical line on left side of screen
The oven paper (referred as ovenable paper some time), is made of wood pulp, coated with food grade silicone oil. It features in smoothness, high-heat resistance and non- stick, etc. The brightness of baking paper is over 88. The sizing value of baking paper is above 0.8.Its strength is more than 3000.
Feb 23, 2013 | Vizio 42 in. LCD TV
Today 12/16/2010 my HDTV 42 in plasma model 42px12x.41. made a "popping" sound in the back of the screen and the screen went black,( yet there is still sound and a couple of green and red light...
PLASMA TVS DONT HAVE INVERTER CIRCUITS. YOU MOST LIKELY HAVE A Y-SUSTAIN BOARD FAILURE. IT IS THE BOARD TO THE LEFT LOOKING FROM THE BACK. THE LARGE ALUMINUM HEAT SINK LOCATED ON THE BOARD AND THE PART SCREWED TO IT WILL BE THE DEFECTIVE PART.
Dec 17, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
My LG 42 Plasma works sometimes then half the screen goes black but the right side stays perfect???
have almost the same problem left side is black with sometime blue line red lines or a whole bunch of different lines some one help please have sound and right side of tv works fine
Sep 26, 2010 | LG 42PC3D 42 in. Plasma Television
3 black lines on the left side of screen, wont go away. how much to fix?
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem
Jul 22, 2009 | Zenith P42W46X 42 in. Plasma EDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Black line from top to bottom on left side of screen one inch wid
This is fairly common. If you don't perform a fix soon, you'll end up with burn lines. Follow this link. Pay particular attention to the soldering part, not the dismantling. A lot of plasmas from the last few years used a LG board made in Korea. The TV in question in this forum is a Hyundai, which is, yep you guessed it, KOREAN. So the pictures of the ribbons are accurate. Don't let someone try to sell you a fix. This sight is supposed to be everyone helping everyone else out. SHAME ON YOU DAVE FOR SELLING HERE!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed-2.html
Nov 16, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Plasma t.v
My hitachi tv # 42EDT41 A 42 in. has a black line from top to bottom on the left side of screen
Dec 23, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
2" black line from top to bottom
my Black line is horizontall top to bottom more to the right hand side
Dec 10, 2007 | LG MZ-42PZ44 42 in. EDTV-Ready Plasma...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
