Can't make a CD from a cassette deck
I am trying to hook up my system to enable me make a CD from my old cassette tapes. Can the unit do that?
  • 4,806 Answers
Yes but you will need a video card and the correct rgb leads or s-video lead to connect the tape player to, then you can record the audio to the hard drive, edit it if you want and burn it to cd :)
nice project, good luck
Posted on Nov 17, 2008
On a kenwood KR597 reciever, where do i hook up my KE597 graphics equalizer. Also must i remove my DP-R797 cd player to hook up my Maeantz PMD520 Cassette deck? Finally divorced
If you only have one set of tape in/out connectors, then hooking up two tape decks and an equalizer is going to be difficult. You could hook the "tape out" to one tape deck, that tape's output to the second tape, and the second tape's out to the equalizer, connecting the output of the eq back to your receiver....
Nov 01, 2014 | Audio Players & Recorders
Trying to hook up older technics stereo dont know
Turntable leads go to Phono.
Turntable ground lead (thin black wire) goes to screw terminal next to 'Phono'
CD phono cables go (unsurprisingly) to the CD
Cassette deck "Play Out" cables go to 'Tape Playback' sockets.
Cassette deck "Rec In" cables go to 'Tape Rec Out' sockets.
EQ Line Out cables go to amp's VCR/EQ Playback
EQ Line In cables go to amp's VCR/EQ Record Out
Aug 30, 2014 | Audio Players & Recorders
I am rigging up an indoor sound system using an old Sony Xplod cassette deck (xr-ca800). I have the unit powered up. I can listen to the radio and tapes, but what I really want is to utilize the R/L...
Those are for the optional CD/MD changer. The deck won't switch over to those inputs unless a compatible changer is hooked up via the bus control. The only way to make this work would require a changer.
Apr 20, 2017 | Sony XR-CA600X Cassette Player
I have had my 1991 lexus ls400 for a couple years now and I've been using the cassette deck in the stock stereo unit all the time by using one of those cassettes with the 3.5mm headset wires coming out...
The tape deck in the unit probably needs to be fixed. Even though you are using an artificial tape supplying a signal to the heads, there are still motors and belts running in the unit if it thinks a tape is in there. Now a belt or a motor has failed and the deck will not stay in tape mode. Thus pulling the unit out of the dash and having it serviced will be required to use this I pod function. There has to be easier ways to do this- I would consult Crutchfield about it.
Nov 08, 2012 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Cassette tape spins fast
Hi Chris..
It's not worth repairing. I would find something else in good condition
Feb 01, 2009 | Onkyo TA-RW244 Single Cassette Deck
Unable to to dub from the radio, phono,or cd
As far as I know, you need to press Record button to record from external source. If you press Dub, it will start Dubbing from Tape-A to Tape-B. You might be need to press Record and later press Pause or Play to start recording.
Aug 15, 2008 | Sony TC-WE305 Single Cassette Deck
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Tape deck does nothing when play is pressed
Maybe a problem of no power to motor. I own 2 identical Aiwa units, both have tape deck problems. This brand is prone to them They also have nasty habit of tape cassette doors jamming.
1st off you never said how old the unit is. Awia have huge amount of models. Mine are the NX series that came out in black plastic. Most of the others are silver/grey. Honestly, unless you pop side screws and lift the cover off to eyeball anything loose. and none is? And if out of warrenty, the value of fix, mat exceed value of unit.
Sorry, but I see many of these,  of 4-5 yr old units Aiwa brand,
get the heave ho!
The most stupid thing about this is: for units size, has the best sound of any other brand it's size.. Brilliant for hooking to ones TV sets, for  surround sound!
What I did was get an older getto blaster  that plays tapes to play my tapes on. some of these units are around and in good order, dirt cheap. And most electronic equipment problems cost at least $35  just to have a quick look at your unit.. cost of repair on top?  I brought my 1st one new @ well over a grond. 3 yrs later, 2ns one, exactly the same $15.00 in a charity shop. The  laser unit was dusty. All go in half an hr. Perhaps if it is an older model , look for another mate to it,   It all comes down to costs.
Which is better option... you are the one who has to made the choice. Good luck. Jamz
Oct 25, 2007 | Aiwa NSX-AJ20 CD Shelf System
62 people viewed this question
 Grubhead
Grubhead
