Question about MagLite Charger System for
Won't light I dropped the flashlight on the ground and now it doesn't light. and the bulb is O.k what can I check now?
Hi bballover64, I've got similar problems, but with two of them. I found some how to's that may answer your problem, Mines is the switch.
Take a look at the following link: http://www.maglite.com/pdf/CustServ/AA_AAA_switch_repair_8_0410212004735472.pdf
Posted on Nov 27, 2008
Repair for Innova GT 3 led, 3 AA battery flashlight.
Before doing serious damage, check for a poor ground to the case. I have worked on a couple of these and some of the manufacturers seem to believe a solder connection to an anodized aluminum case is going to work. Use a tool with a sharp point to scratch through the anodized layer to expose a clean metal ground. You may have to repeat this from time to time as the light fails.
Aug 26, 2016 | Camping, Backpacking & Hiking
I have a 1997 chevy malibu and the driver sid light high and low beems are dim and i replaced the bulbs amd the hedlight fixtur its self its as bright as a flashlight befor it bows
It could be a bad ground. Try using a jumper wire directly to the ground side wire with the light plugged into the bulb. If ground is bad bulb will get brighter when you add your ground wire.
May 30, 2015 | Cars & Trucks
97 Oldsmobile bravada my right brake light won't
Sounds like a short in the socket or a bad ground.
The parking light is one circuit and the brake turn signal is another.
Jul 24, 2013 | Cars & Trucks
Need a replacement bulb for a Redline Nebo flashlight
Hi, replacement bulbs can be found at amazon, click here and take a look: Amazon com flashlight replacement bulb. Cheers
Nov 02, 2012 | Nebo Redline Tactical Flashlight Strobe...
I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Sep 18, 2012 | Fenix TK15
The flashlight won't turn on even though it has new batteries.
Check the bulb. Unscrew the light to inspect the contacts for the batteries and (as possible) unscrew in a place you can check the contact points for the bulb, switch and bulb. A simple cleaning with a contact cleaner, WD40, dry wool or as possible a blade (knife).
Mar 24, 2012 | Inova Camping, Backpacking & Hiking
Freezer dropped to -12 won't stay at -1
freezer light does't work, I put in new bulbs and it doesn't stay cold.
Dec 06, 2011 | Sub-Zero 632 / S
Hello, I have a 97 eldorado with a tailight problem. My rear left doesn't get bright when i turn on my turn signal or hit the brake. My fron signal works fine, and the right light get brighter with the...
Now remove the bulb & put your volt meter to the
center socket contact & ground your blk lead.
See if you get 12.6 volt back to the socket
If not,then you have a voltage drop before the socket
I hate to suggest a wiring diagram, as your doing good
so far,BUT you may need one, after you get dirty under the
car some more following the wiring
Jul 02, 2011 | 1997 Cadillac Eldorado
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
MagLite Charger System for Logo
174 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
