Question about HP Office Equipment & Supplies
How do I edit an image that has been scanned?
  • 903 Answers
Open the image in photoshop or jasc paint shop and you can edit it from there, adjusting colours, resizing adding text etc.. etc...
Posted on Nov 16, 2008
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do I scan and email a document
To scan to a computer
1. Load your original print side down on the right front corner of the glass.
2. Press Scan.
A preview image of the scan appears on your computer, where you can edit it. Any
edits that you make apply to the current scan session only.
The HP Photosmart Software has many tools that you can use to edit your scanned
image. You can improve the overall image quality by adjusting the brightness,
sharpness, color tone, or saturation. You can also crop, rotate, or resize the image.
3. Make any edits to the preview image, and then click Accept when you are finished.
Once done, You can save it to any folder. Please make sure you remember where you stored it.
To send as attachment to the email:
1 Simply open your email ( if Outlook or any software // Online)
2. Click on the pin ICON (Attachment Icon if any) - Attach FILE
3. Browse for the scanned File and click attach
IF YOU NEED THE COMPLETE INFORMATION OF THE PRINTER YOU CAN DOWNLOAD THE USER GUIDE
HERE'S THE DOWNLOAD LINK - click - HP_F4280UserGuide
Hope this helps,
Good Luck
Mar 11, 2011 | HP DeskJet F4280 All In One Printer InkJet
I am out of ink cartridges (none in the printer) but I just want to scan something...how can I do this?
You can still scan using either the command menu on the scanner or the HP software from you computer. As long as you are not trying to print, having no ink should not effect the scanning.
If you have the HP solution center software, you can open that application and pick scan a document or scan a picture.
From the PSC 1610v controls follow these directions:
Scan to an application
You can scan originals placed on the glass directly from the control panel.
1. Load the original face down on the right front corner of the glass.
User Guide 59
Use the scan features
2. In the Scan area, press Scan To.
The Scan To menu appears. The Scan To menu lists destinations, including
applications, for anything you scan. The default destination is the one you
selected the last time you used this menu.
The Scan To menu can be configured. You can designate which applications and
other destinations appear on the Scan To menu by using the HP Image Zone
software on your computer.
3. To select an application to receive the scan, press until the destination you
want appears on the control panel display, and then press Start Scan.
A preview image of the scan appears in the HP Scan window on the computer,
For more information about editing a preview image, see the onscreen HP Image
Zone Help that came with your software.
4. Make any edits to the preview image in the HP Scan window. When you have
finished, click Accept.
For more information on editing a scan in the HP Scan window, see the onscreen
HP Image Zone Help.
The HP All-in-One sends the scan to the selected application. For example, if you
chose the HP Image Zone, it automatically opens and displays the image.
If you don't have the HP solution center, you can download it from this link:
http://www.hp.com/global/us/en/consumer/digital_photography/free/software/photo-creations.html
If you found this answer helpful, please remember to leave positive feedback.
Mar 01, 2011 | HP PSC 1610v All-in-One Printer
How to scan
Here is the manual:
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
Page 45 will give you the scanning instructions.
1 Load your original face down in the right front corner of the glass.
2 In the Scan area, press the Scan To button.
The Scan To menu appears, listing destinations, including applications, for
anything you scan. The default destination is whichever one you selected the last
time you used this menu. You designate which applications and other
destinations appear on the Scan To menu by using the HP Image Zone on your
computer.
3 To select an application to receive the scan, use or to select it, and then
press OK or Start Scan.
4 Make any edits to the preview image in the HP Scan window. When you have
The HP all-in-one sends the scan to the selected application. For example, if you
chose the HP Image Zone software (Windows) or JPEG to HP Gallery
(Macintosh), it automatically opens and displays the image.
Jan 27, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do I get my hp f4280 to scan to my comp.
Hello Lulu !
To use the scan features, the HP All-in-One and computer must be connected and turned
on. The HP Photosmart Software must also be installed and running on your computer
prior to scanning. To verify that the HP Photosmart Software is running on a indowscan
computer, look for the HP Digital Imaging Monitor icon in the system tray at the lower
right side of the screen, near the time.
1.
2. Press Scan.
Heres a link you will find everything you need to know about the f4280 (scan features starts on page 63) :
http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Jul 15, 2010 | HP DeskJet F4280 All In One Printer InkJet
How do i get my scanner to work?
well did you go to my computer and put the disk of your printer and install it??
May 23, 2010 | HP PhotoSmart C4280 Laser Printer
When I scan I cannot edit the image scanned what is the process of scanning that will enable the image to be edited?
Start by opening the software on your computer that you would use to edit an image. From within that software find a way to access the scan feature... the interface for this may say "Twain". You would probably find that option under the File heading. Then edit using the software.
Jul 17, 2009 | Mustek Scan Express 1248UB Flatbed Scanner
Cannot edit my scanned images any more
There is a software in the HP CD which is called an OCR software. This is Optical Character recognition. Only with the help of the software you will be able to edit the scanned documents. This software ded not gets installed with the drivers so pleas check this in the CD. Also you can try fine reader software for editing your documnets. You will be able to find it on google
Jul 08, 2009 | HP PSC 1410 All-In-One InkJet Printer
I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
May 08, 2009 | Office Equipment & Supplies
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
