Question about Polaroid PLA-5048 50 in. HDTV Plasma Television
Picture too large
My dog stepped on my remote control. Now my picture is very large. How do I get it back to normal?
    Champion:
  • 225 Answers
Find the "wide mode" or "zoom" button on your remote or something similar.
Posted on Nov 17, 2008
My remote won't work
Many remote controls freeze up and appear "Dead", but some can be instantly brought back to normal operation by following 4 simple steps.
Use these steps on OEM (original equipment) remote controls for TVs, DVDs, Audio Systems, Satellite and Home Theaters.
Note: If you follow these steps on a universal remote control, you will need your universal's owner's manual to reprogram it.
1) Remove all batteries from the remote
2) While the batteries are out of the remote, push and release every button on the remote control one at a time, until all buttons have been pressed and released at least once. This action drains the capacitors in the remote's circuits and causes the remote's brain to go back to factory defaults.
3) Re-install the batteries, taking care to insure each battery is installed correctly. Use new batteries if you are unsure about the batteries you removed.
4) If this Remote Re-Start procedure is going to work, your remote should now be back to normal. Try it.
If your remote works, Great. If not, you can shop for a new OEM remote control at Remotes.com 1 800 Remotes Factory original replacement remote controls
If you need codes for Universal remotes REMOTE CODES COM
Feb 29, 2016 | Televison & Video
My dog stepped on my entone urc plus. I can still pull up the guide and select channels (the stb button lights up) but there is picture or sound. Help!
It sounds like the tv is either set on the wrong input of the tv (check the back of the tv set and verify the input number) then use the remote's input button to change to that input number, OR the tv is not set to channel 3 -if using a cable box!
Good Luck!
Rich Lilja
Jan 05, 2014 | Televison & Video
How do I get full picture back?
Look for the aspect button on the remote.
Dec 13, 2012 | Toshiba CT-90157 Remote Control
Tv picture size
reset the code download from www.remotecodelist.com
open the remote and clean the KEYpads from corrosion, dirty, dust, or oxide, this happen since the Syscon control all information.
if does not work, go to the repair shop TV for fix it.
God bless you
Sep 09, 2012 | Logitech Harmony 650 Remote Control
PICTURE ON TELEVISION TO LARGE FOR SCREEN
Look for a "Zoom" button your remote, it sounds like you've inadvertently activated a zoom function on your TV. Press the Button a few times with an image you know the correct size to, and see if it returns to normal.
Nov 02, 2010 | Hitachi CLU-5713TSI Remote Control
The picture is too large, when watching it the picture is so large I cannot see the tops of the keads. How can I lessen the picture size
Use your remote control to select the picture "format", you should have at least four choices, normal, wide,panorama,full. Good luck Julio at Millenium TV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Picture on screen is to big
Picture zoom may have been activated. Try MENU on remote and select "Picture" and look for "Normal", Zoom1", "Zoom2", "4:3", etc. Select normal or auto and exit.
Good luck
Techjoel
May 13, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Toshiba TZ50V51
Small dog or large==coincidental/unrelated to problem!General service includes some very precise soldering==requires chassis pull. One or more micro-fuses will be bad and STK IC's should be replaced.Alignment in servicer menu may be needed after repair completed.
Oct 03, 2007 | Mitsubishi WS-55807 TV
Polaroid PLA-5048 50 in. HDTV Plasma Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
