Question about Amana ASD2326HE Side by Side Refrigerator
Amana side by side compressor not running
Compressor clicks and is hot. No cooling. Cooling fings were all fuzzed up. I cleaned. Help!
  • Anonymous May 22, 2008
    I have a older unit (7yrs) The cooling fan runs but the compressor will not.
    you can here the switch click but nothing happens.
  • elaggahjoh Jun 08, 2008
    Refrigerator Will not run, get cold, cant do anything.
  • 237 Answers
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Posted on Nov 30, 2006
Amana refrigerator not cooling, what should be done or what should we check to determine the problem?
The purpose of a refrigeration circuit is to move heat from the inside of the cabinet to the outside.
The compressor pumps refrigerant around the circuit and if everything is ok the evaporator is cold and the condenser becomes warm. If the compressor is running but nothing inside or outside is happening either the compressor is defective or the refrigerant has leaked away.
If the condenser is warm or hot but the inside is not cold the defrosting panel might be permanently switched on.
Nov 27, 2017 | Amana Refrigerators
Amana bottom freezer/frige not cooling. Clicking sound then buzzing sounds and clicks off. Compressor hot. Hear it running but no cooling.
Solution to this recyle-Amana is to scrap it and get a "GOOD" brand!!
The condenser/compressor is made by Tucumsah, excuse the spelling, but you know what I'm saying.
Jan 15, 2013 | Amana ABB1927DE Bottom Freezer...
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fan works but the fridge does not coll freezer does not freeze
Does it get cold at all... gots to know...to help hehehehee
Aug 18, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ASD 2620HRZ side by side not cooling at all!
if all of that is running your ref. should be cooling.can you hear your compressor running?or can you hear it run for a few seconds and click.If you hear a clicking noise the relay to compressor has gone bad,if it is running then you have a leak in the sealed system.
Mar 08, 2009 | Amana ASD 2624 Side by Side Refrigerator
COMPRESSOR STOPPED WORKING
if the compressor isn't running and is hot or you hear it clicking noise then replace the overload rely on the compressor its the little whit box on the side of the compressor shake it after taking it off and if it rattles and black stuff falls out the thermo disc is bad
Dec 31, 2007 | Amana ASD2626H Side by Side Refrigerator
Compressor not running.
The fan running near the compressor is a good thing. If you suspect the starter it is the little box on the compressor. It usually consists of the overload and starter. You may also have a start capacitor, if you do you will need a multimeter that can check capacitors. Read the case, it should be say like a 5uf (micro farad) or something like that. They make kits to replace the starter/overload combo and also sell just a capacitor if that tests bad. I have seen some starters that are white in color with a small white plastic clip that holds the cover on go bad recently. If you have this type, take it off and shake it. If it rattles it's bad (really).
Nov 29, 2006 | Amana ARS9265B Side by Side Refrigerator
Amana ASD2326HE Side by Side Refrigerator Logo
1,135 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
