Question about Sony DHC-MD333 Shelf System
Sony DHC MD373, CD player skips portions of first track on CD's.
The system functions normally after this. Can I buy a replacement CD player. It seems fairly easy to change.
  • Anonymous Mar 04, 2009
    the problem only occurs with the first cd-track!?
    i have cleaned the cd-lens but with no result.
ALL DISKS SKIP ON MY SONY CDP - CX53...SOLUTION?
If you have access to the lased head, gently wipe the lens with a stick with cotton moistened with isopropyl alcohol, or regular sanitary alcohol. Use circular movement. Then, gently shine the lens with dry cotton. DO NOT PRESS THE LENS !!!! If the issue persists, it's more complicated. You need to have access to the tiny trimmer below or near the laser head. Using a plastic screwdriver, rotate the trimmer clockwise about 2-3 degrees. Test playing. If track doesn't skip, hit the CD player's case with the finger, to check if track skips because of shock. If skips, rotate trimmer again 1-2 degr. Check again. If it doesn't work, try rotating counterclockwise. You need patience. Hope it is useful.
Mar 11, 2015 | Sony Audio Players & Recorders
Sony cdp cx 355 skips on first track
Could be some dust or debris in the unit. Also be careful that you are not putting fingermarks near the hole section of each CD you put in, as the CD plays from the centre out.
Jul 02, 2017 | Sony MegaStorage CDP-CX355 300-Disc CD...
Yamaha cd-2050 skips until it has warmed up
Buy a CD cleaning kit and follow the instructions, it may buy more time out of the player, if not! the laser pickup assembly is just about finished, it will reach a point that it will not work, far cheaper to replace.
Mar 23, 2012 | Yamaha Audio Players & Recorders
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
CD player not tracking right
These are the early signs or optical lens assembly failuer. i would start preparing to replace this assembly. the tracking motor and rail are damaged.
May 28, 2009 | Audio Players & Recorders
Cd player skips
To clean the cd will involve disassembling the main unit which I dont recommend as things are tightly crammed in and difficult to get to.
As for adjusting you will need an oscilloscope and a deep understanding of cd players if you dont want to risk burning your laser out.
If you do decide to clean inside the player, use a good quality camera lens cleaner with some lint free swabs, this will often improve things if the player has been used in a smokey enviroment.
Apr 05, 2009 | Sony DHC-MD333 Shelf System
Sony MHC-GX450 CD's Skip
Try using a laser lens cleaner. I have the Maxell Thunderon one thats on a Gold CD that you can get at best buy for like $20 or so, seems to work good here on the computer disc drives
Nov 17, 2007 | Sony MHC-GX450 CD Shelf System
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
Sony DHC-MD333 Shelf System Logo
662 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
