Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven igniter causes small explosion
Installed a new igniter in a GE oven/range and when I turn it on it takes approx. 1.5 to 2 min to ignite the gas. When it does the broiler sounds like it explodes. I was wandering if the igniter needs to be in a certain position in order to lit the gas.
  • 833 Answers
Sounds like the ignitor is worn or mispositioned or the gas mix is wrong.  Could also be a worn burner.  Don't do this yourself unless your fire insurance is up to date.
Posted on Nov 16, 2008
Takes a while to ignite and when it does the build up of gas causes an explosion that is increasing in size each time I turn it in both oven and range
PDF]Gas Range Delayed Ignitions - Consumer Product Safety ...
https://www.cpsc.gov/.../Kitc... U.S. Consumer Product Safety CommissionJul 15, 2002 - Investigation of Delayed-Ignition Range and Igniter Aging . ... and ovenexplosions and flare-ups attributable to delayed ignition of gas.
Jul 19, 2015 | Kitchen Ranges
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
Jul 18, 2014 | GE Spectra JGBP35 Gas Kitchen Range
Delayed oven ignition
see the next steps and proceed with common sense:God bless you
Fuel Type
If this is a new installation make sure the gas valve has been properly adjusted for the type of gas. Lp and natural gas use different orfices and pressures. A conversion kit is available.
Burner
The burners may need to be cleaned. There are small holes that allow gas through holes that are ignited by the igniter. These holes can become clogged up. You can usually clean these with a toothpick or small wire, watch the video. If it is the oven burner and you have a small flame or it does not stay lit check the video on troubleshooting a gas range.
Gas Valve
The gas valve rarely fails but this can. If the gas burners are clean and the gas valve is properly adjusted replace the gas valve. This should be done by a professional. Leaks can be very dangerous and also the gas pressure needs to be adjusted for the type of fuel you are using.
Jul 27, 2012 | Kitchen Ranges
GE profile Spectra gas range/oven is taking approx.20-30 min to preheat. Once it finally reaches temp. it seems to hold at that temp and maintain it. I have noticed occasional puffing sounds when it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 17, 2011 | Ovens
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Oct 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Oven not heating up to temp. Sometimes get small explosion inside when starting. Sometimes small slight gas when lighting. Top burners work fine. Model GE JGBP26GEJAWH
heatman101
gk
Aug 13, 2009 | GE JGBP26 Gas Kitchen Range
The oven gas does not come on? Top and Broiler does. Oven igniter does glow
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter is on, gas is released, a small explosion occurs in oven
no the little boom before it lites is normal mine does it all the time
Dec 04, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
324 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
