Question about Casio Parts Cash Register PC Desktop
I cannot change the price for an item on CASIO TE-2400 register
I've recently purchased the Electronic Cash Register Casio TE-2400.
1. I cannot set the price for an item by barcode (EAN-13) in PGM mode.
I following the steps on page 35 of user manual.
- use KEY to switch to PGM mode
- press "1" key
- press "SUBTOTAL" key
- enter unit price "2.99"
- press a department key "DEPT 01"
a line gets printed on the receipt
- scan the bar code
get a long single beep (it sounds angry!!)
- press "SUBTOTAL" key to exit
The manual suggests "Flat-PLU" - should there be a flat PLU button somewhere on the register?
I'd like to attach an image of the keys that are on the register I got as certain keys seem to have been overwritten with different functions.
e.g. "MENU" (fifth button from the right on top row) is changed to "RCPT ISSUE"
e.g. "PLU" (third button from the right on top row) is changed to "END OF DAY REPORT"
I can set the price and department of an item in REG mode (REG1)
- Scan barcode (EAN-13)
get message stating that PLU is not recognised...
- Enter unit price (2.99)
- Press a department key "DEPT 01"
This barcode item is now successfully set to 2.99 in DEPT 01.
What do I do now if I want to change the price of the item?
One would expect this should be done in the "PGM" mode - yet I have no joy in scanning any item in PGM mode.
2. I'm also having difficulties entering item descriptions following instructions on page 88 of the user manual.
I must say that I'm disappointed that the user manual has not been able to help me resolve one of the most basic requirements of a cash register.
Can anybody help?
Caller171
  • caller171 Nov 18, 2008
    Hi Mark,
    Thanks for your prompt reply.
    This kinda confirms what I had suspected. This cash register is not for the faint-hearted.
    There is no dealer. I purchased this on Ebay where I was assured that all I had to do was scan in my items in PGM mode and enter the item name and price. Needless to say this has not worked for me.
    Unfortunately, there is a time pressure as we need to have this in production next Saturday.
    From my searching I've found a dealer manual (TE22_24DM_E050830A) that has more programming instructions. But I am still struggling with how to change the price. Following instructions on "Scanning PLU direct maintenance programming" I have managed to make the barcode for an item un-readable in REG mode - so this is progress!!.
    We have a fall back position where we can set up 10 departments and scan items in REG mode and set the price and Department - This will be adequate to get started. But imagine if someone keyed in a price incorrect or pressed the incorrect department (unbelievable as that may sound!). We still need the ability to correct the price or department. And prices will change - we need the ability to change the prices.
    Is there any help you can give me to change the price of an item?
    Attached is the key layout on the register.
    I will also ask the supplier for more information.
    Thank you,
    Caller171
  • caller171 Nov 20, 2008
    Normal
    0
    Thank you flexion1,
    You're spot on.
    Unfortunately, there seems to have been a bit of a problem between the chair and the cash register!!!
    After reading the user manual, and over half of the Dealer manual - I went back to the box to find an 8 pages or stapled together that explained some of the tasks I require.
    I have gained a reasonably in-depth knowledge of the TE-2400 and used to change the layout of the keyboard slightly.
    Essentially, your method is correct, however I was struggling with the CASH,CASH,CASH - basically accepting defaults for bottle link and status and stuff..
    For anyone who is interested.
    Here are steps to change Price and description individually.
    Change the stored Price of a barcoded Item
    1. Turn key to “PGM” mode
    2. Press ‘3’
    3. Press ‘SUBTOTAL’
    4. Enter 0171
    5. Press ‘SUBTOTAL’
    6. Enter 2166
    7. Press ‘SUBTOTAL’
    8. Scan item which requires the price change
    9. Enter the new price (without a decimal point)
    10. Press ‘CASH’
    11. OPTIONAL - Repeat steps 8 to 10 if required for other items.
    12. Press ‘SUBTOTAL’ to finalise
    PRICE = CODE 2166
    DESCRIPTION = CODE 2266
    DEPARTMENT = 1166
    Thanks for all your help,
    Caller171
  • 737 Answers
Hi. I'm afraid this is not a 'basic requirement' of a cash register. You are working with a very complicated area of cash registers that only the medium to high end machines can even do. If you are getting stuck already, then you will not be able to work out the more complex batch processing areas of scanning either.
Your dealer should have setup the majority of this for you before you left their store (especially the keyboard layout issue and keysheet for the keyboard), then you would normally receive extensive training if you are going to be making program changes yourself in future.
You will need to learn about the difference between flat PLUs and scanning PLUs, 'Not found PLUs' like you have run into so far, then deletion techniques, PLU status programming, manual entry using OBR method etc. The book is only a guide to what you should have learnt during training. You really need to go back to the dealer and get a training session. They should be able to sort out all of these problems for you. It will take a one on one demo to fully train the ins and outs of full scanning systems.
Mark
Posted on Nov 17, 2008
  • flexion1
    flexion1 Nov 19, 2008
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Ok. I have written up a basic scannign PLU adjustment system for another customer who has a TE4000. I think yours should be the same.
    Turn the key to the PGM
    position.
    2.
    Press 3.
    3.
    Press SUBTOTAL.
    4.
    The display should show “P03”.
    5.
    Type 0071 SUBTOTAL
    6.
    Press 0 to add a new product, or 1
    to change an existing item.
    7.
    Press CASH
    (continued in next post)
  • flexion1
    8.
    Scan the product’s barcode
    9.
    Type the price (without
    decimal point) e.g. $5.50 = 550
    10. Press CASH
    11. Press a department button (category) for this item e.g GROCERY
    12. Using the alphabet keysheet (usually on the reverse of your keyboard)
    type the product name
    13. Press 00 (double zero button)
    14. Press CASH
    15. Press 2
    16. press CASH CASH CASH (MUST
    PRESS IT 3 TIMES)
    17. If you want to do more items, go back to step 6
    18. Press SUBTOTAL when finished
How to setting new te2400 with scener zebek s3000?please help me!!!thanks
Posted on Jan 19, 2010
    Problem Solver:
  • 9 Answers
Cash register helpline for United Kingdom, call charged at £1 per minute :- 0905 105 0159
Posted on Feb 13, 2009
    Problem Solver:
  • 14 Answers
Just call Casio or email DWONG@CASIO.COM, ask him to email u the scanner barcodes to program the scanner tell him the model and make of the scanner u have . All thats needed is to program the scanner Its a easy fix, or dealer they are called the cash register store located in FL
Posted on Nov 19, 2008
My Casio TE-2400 is showing =w/ when in REG mode and in PGM mode, doesn't show the number of the program I want to access. Any ideas please?
Someone has been fiddling with function key names. Do a program print out of PGM2 mode and find which name has been changed to =w/ in the list. Program it back to original.
Jan 05, 2017 | Casio TE-2400 Cash Register
I cannot set the time and date on my cash register when I turn key PGM it shows "ae 01" and no 000 what do I do?
Error 01 means that a previous activity has not been completed. Here is a link to the manual: http://totalpos.co.nz/wp-content/uploads/2012/10/Casio-TE2400-Operator.pdf
May 10, 2015 | Casio TE-2400 Electronic Cash Register
How do I load the IPL to a CASIO TE-2400?
that is the correct way . Maybe you need to activate sdcard option on the new machine it could be off
Apr 30, 2014 | Retail Supplies
How do I program a MISC key on a Casio TE-2400 cash register?
You just use one of the item buttons. Re-name it to MISC then when you use it in REG mode, type a price each time and press MISC. This is the standard way to make a MISC button Make sure you don't use a decimal point when entering prices. Hope that makes sense
Mar 28, 2013 | Casio Parts Cash Register PC Desktop
Casio te-2400 cash register- making transactions
Try this: Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
This should remove the preset amount from the CASH button. Now it should work normally when finishing the sale.
Now turn back to REG mode when entering the price, DO NOT use a decimal, so type 2000 for 20 dollars. Now press a PLU (item) button. SUBTOTAL Type the amount received (NO DECIMAL, so 5000 for 50 dollars) Press CASH Change should be displayed, and drawer open
Looking for a manual for a Casio TE-2200, TE-2400 cash register? Go here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Jul 10, 2010 | Casio Parts Cash Register PC Desktop
Casio TE-2400 sales transactions
If anyone needs a manual for a Casio TE-2400 cash register, go here:
HOW DO I CHANG PRICES ON MY TILL CASIO TE 2400
Turn key to Program Type the new price (NO DECIMAL POINT) Press the item button that you want to save it to Press SUBTOTAL
If anyone is looking for a Casio TE-2200 / TE-2400 manual, try here:
Many more available at http://the-checkout-tech.com
Mar 24, 2010 | Casio Parts Cash Register PC Desktop
Te-2200 change price
Yes, u need to do it in PGM3 to change price for scanning PLU. The PGM1 is for Normal PLU price change.
Of course , u can use Casio CV-10 software to do the price change too.
Sep 10, 2009 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
1,800 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
