Question about Acer Aspire 3690-2196 Notebook
Keeping the power on
My laptop suddenly started shutting itself off when i was in the middle of using it, or it won't turn on in general. i have tried other power outlets thinking it might have been something with that, but no matter what i do, it doesn't seem to matter. can you please help me?!
    Sergeant:
  • 237 Answers
Firstly, check that your laptop receives status lights. Are they on? Is your battery status lights on?
If those check out, then....most important....how long do you usually keep your laptop on and working? Is it in a cool, normal, or hot climate? Do you hear a loud noise when turned on? Where do you place your laptop when you are using it?
If those questions point to long hours, hot climate, and loud noises that usually aren't there, then you may have overheated your laptop....
Posted on Nov 17, 2008
    Champion:
    Scholar:
  • 209 Answers
I have seen that problem before, but on a desktop. I guess you have tried all the connectors available in your house. Hmmm! It think, not sure, but pretty sure, it is the motherboard the problem.
Posted on Nov 16, 2008
Won't Power On
Tree things to workaround:
1-RAM memory
2-CPU
3-Motherboard.
Because the RAM is less expensive start by change one of the stick and keep testing otherwise turn up by your next shop.
Apr 12, 2013 | Dell Inspiron M5030 Laptop
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Engine shut off in the middle of the freeway, completely lost power.
check the crank shaft sensor ,check the timing belt . check the coil , check the fuel pump pressure
Sep 08, 2012 | 2003 Saturn VUE
My laptop turned off but it has 35% remaining battery
Laptop turns off suddenly? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage.
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
May 29, 2010 | Computers & Internet
Turns off suddenly
Mar 27, 2010 | Toshiba Satellite M55-S331 Notebook
Shut down suddenly now keeps trying to start
Dear what you tried is best only apart from there no solutions from front end, check your system is rebooting or not. Please take backup of all data from your harddisk then put recovery C.D for restore your laptop O/S .
Feb 26, 2010 | Acer Aspire One PC Notebook
My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 minutes then turns itself off automatically how do i stop this? My HP laptop keeps shutting itself off after...
Sounds like something to do with a power saving feature either from HP itself or from Windows. It could also be that for some reason your computer is overheating, which it than shuts itself off to protect the processor. I would try playing with your power saving features, and cleaning out the fans.
Mar 13, 2009 | Computers & Internet
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Fujitsu Siemens AMILO PRO V3515 - keeps turning itself off
This is the classic signs of a Virus.
You need to recover your data, format and re install your operating system.
If your computer suddenly switches off when you move the computer arround then it could be
your Power Jack that is faulty. Check diagnostics at: www.powerjackrepair.com
Dec 09, 2008 | Fujitsu Siemens Computers & Internet
Random shutting down
Your CPU is heating up it will shut down on you the fan that keeps it cool must of clapped out replace it. Then you should be right..
Sep 12, 2007 | HP Compaq Presario V2000 Notebook
Acer Aspire 3690-2196 Notebook Logo
63 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
