I just pulled into the garage and noticed a strong gasoline smell.
My husband said he heard a sort of subtle "clanking" sound as I pulled in. I am afraid to start the car until the gas smell goes away. It drives fine, it has about 70,000 miles. I filled it up yesterday.
Pop the hood and check all the fueling lines, then check your gas tank and see if you just spilled some. Then check your exhaust pipes because you are probably running rich. You may need to change your spark plugs, or possibly a mass air flow sensor, or oxygen sensors. you should get either a vagcom to scan it or an OBD-II scanner.
