Question about Amana ARS9265B Side by Side Refrigerator
Compressor not running.
Like other ad listed... Compressor off. There was loads of fuzz on the cooling lines. I cleaned it off. Ha dunplugged 45 min. Now, fan and no compressor. Compressor is warm still. Clicks when plugged in. IF it is the starter, where and can I fix it or is it electrical?? HELP and thanks! RT
  • 237 Answers
The fan running near the compressor is a good thing. If you suspect the starter it is the little box on the compressor. It usually consists of the overload and starter. You may also have a start capacitor, if you do you will need a multimeter that can check capacitors. Read the case, it should be say like a 5uf (micro farad) or something like that. They make kits to replace the starter/overload combo and also sell just a capacitor if that tests bad. I have seen some starters that are white in color with a small white plastic clip that holds the cover on go bad recently. If you have this type, take it off and shake it. If it rattles it's bad (really).
Posted on Nov 30, 2006
Why dose the front unit work fine and rear unit only blows air
There are lots of possibilities. Are you perhaps just running just the fan? Is the inside air below the thermostat setting? Is the compressor engaging? If the compressor is running, what is the current draw on the common line going to the compressor? A white tag on the housing should show the RLA for the unit. RLA: Acronym for "rated load amps". The maximum current a compressor should draw under any operating conditions. Often mistakenly called running load amps which leads people to believe, incorrectly, that the compressor should always pull these amps. You should never use the listed RLA to determine if the compressor is running properly or to condemn a compressor. The running amps of a compressor are determined by the evaporator temperature, condensing temperature and the line voltage.
If it is at the published specs for current draw then perhaps the just cleaning the evaporator and condenser will restore the unit if you can feel that the output of the compressor is nice and cold. Also a broken cover can make the unit not channel air properly through the condenser and evaporator. A missing baffle or large seams in the ducts portion that separate the intake from the outflow will cause the unit to recycle the cold air and not distribute the cooled air to the duct system.
If the compressor is not running, it could be a bad start capacitor or the temperature cutoff switch. It could also be a defective control board or thermostat. A test light on the output plug of the control board will help isolate the problem.
Jul 28, 2014 | Dometic Rooftop RV Air Conditioner
My magic chef model ctn1911gew is not working properly makes a clicking sound and is not cold at all and fan on bottom is not running. please help
Are we talking about the fan near the compressor? It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. It will click trying to turn on untill the over load gets hot Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is not running could itself be the problem. It is needed to keep the freon, and the compressor cooled.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
I own a Fogel Fridge Model # VR-17-RE-PR Recently
Richard,
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
At 100 deg.it does not shutoff automatically
If your talking about a refrigerator, it never will as its goal is to try and cool, and its trying. It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load itself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your frig is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Kitchen Appliances - Others
Refrigerator running but not cooling
Check list:
fan motors all functioning
Cooling coils free and clean
Compressor cool to the touch
(compressor blazing hot bad relay)
Backside of freezer section frosting up
(bad defrost heater,thermostat,or timer)
Small line from compress is HOT
(cool high pressure line means low charge)
Suction line frosting up (overcharged)
Generic ice box Training manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2010 | Kenmore Refrigerators
Compressor kicks out and it's new
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Jun 25, 2009 | Ruud UAMB Air Conditioner
Heat Pump no longer produces cold air. Blows good but not cold.
make sure the coils are clean run unit a bout 20 min take cover off and feel the lines on the compressor the big one should be cold and small hot feel top of compressor to make sure running
if big line not cold most likley freeon has leaked out if compressor not running low psi may have unit out look at the compacitor if swelled up bad hope this helps
May 22, 2009 | Heating & Cooling
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator compressor clicking
Relay on the compressor bad.
Try unpluging for 30 - 45 min until the compressor has cooled down then plug it back in. If it doesn't start replace the relay. Most service techs carry a universal relay and wiil put the relay on, if it starts, your good to go, if not, then the compressor is bad.
Nov 07, 2008 | Jenn-Air JCD2389G Side by Side...
Amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Nov 29, 2006 | Amana ASD2326HE Side by Side Refrigerator
Amana ARS9265B Side by Side Refrigerator Logo
340 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
