Use of ''PIP'' on a hitachi ultrvision tv
I lost my manual for my 55'' tv I have it hanging on the wall and it is har to see behind it. When I switch from regular view to picture in picture, one side shows a picture the other shows AIR for input and no picture. It will not let me change the input at this point , how do I get to use the feature, Gary?
SOURCE: pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Posted on Nov 04, 2007
Shuttle83
  • 1139 Answers
SOURCE: Hitachi 55" Plasma HDTV, 1 yr old, suddenly lost picture and sound, but power light still on.
It sounds like a shutdown circuit is being activated. This is normal in cases where the power supply id drawing excessive current. I would suggest that you get this looked at by a qualified professional. This is because this problem may be in the power supply and the voltages can get dangerous in this section of the TV set.
In any event if this is a power supply problem chances are the technician will just have to replace the power supply. Which should cost from 150-250 dollars.
I hope this helps
Shuttle83
Posted on Jul 14, 2008
SOURCE: My JVC PIP Won't work, pls help!
I was told that in order to view 2 different channels at the same time u have to subscribe to SKYCable and use the digital input instead of the antenna input and the antenna input you will have to use the regular antenna since there is only one tuner in the TV
Posted on Jul 26, 2008
  • 1039 Answers
SOURCE: Hitachi plasma screen black. blue light on... no picture though.
Replace digital board. Common for this set.
Posted on Nov 09, 2009
  • 19 Answers
SOURCE: How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Posted on Mar 27, 2010
What board would be needed to repair hitachi 55hdt79 lost picture sound ok?
Good one (great description).
Power-board...!
Those gum-wrapper capacitors they are using can snap when they croak.
Have fun save $$$$
(but take lots of detailed pictures BEFORE you start).
Jan 03, 2016 | Hitachi 55HDT79 55 in. Plasma HDTV
Hitachi 55vf820 problem
Most likely the buttons on the tv are stuck or malfunctioning, replacment of the button pannel will solve the issue
Mar 17, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Picture in picture Mode will not turn off
Your universal remote control does not have the PIP control feature of the original.
Jan 01, 2018 | Hitachi Televison & Video
The tv cycles on and off
dry soldering on EHT out put side horizontal SEXCTION
Jan 15, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi Ultravision Projection Tv problem
Hitachi TV also Model # 46UX7K, Serial # W1H002013. I was hoping I can get help with this one too. The picture is dark and has lost most of it's color. I don't know if the color is off because it is so dark. Is there parts that I can buy from you to fix this problem.
Aug 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I have an older Hitachi 36'' Ultrvision TV. It has worked fine for years up until resently. The problem that I am having is I can not get the direct TV signal to come in. The out from the Direct TV box...
Sounds like you have something in the wrong setting that won't allow the signal to get through. If the video 1 line works OK but regular input will not work, that is almost certainly the problem. I would try just unplugging it (turning it off is not the same thing), let it reset for a few minutes; then plug it back up and see if it will reset by itself. hope this helps.
Jun 11, 2009 | Hitachi Ultravision P50S601 50 in. Plasma...
Will not turn on. TV is pluged in its almost like a power surge. The power bar is lit so for some reason the tv is not getting power.
PIP trouble
Hitachi Tricked consumers into beleiving that true PIP was possible
It's not,you can only use any 1 source( dvd vhs ) and A cable signal via the co ax input (hence the term AIR)
Sep 25, 2007 | Hitachi 55HDS69 55 in. Plasma Television
Lost my picture when went to pip
Check your PIP source. I couldnt figure out my LCD pip, and why it wasnt working either until I was able to switch the source. It was automatically using a source that didnt have anything hooked up to, I had to switch mine in order for it to work. Try that and see if that might be the case. let me know. thanks!
Sep 24, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
