Question about AEG B1180-4 Electric Single Oven
AEG B1180 single oven
Where is the thermostat and how does one access it?
  • AEG Master
  • 3,463 Answers
Hi.
The thermostat is the control with the temp marked on it.
You can acess it by removing the top cover of the oven.
Posted on Nov 20, 2008
My oven is locked out and I cannot get it to work
Is the digital clock/timer set correctly? Sometimes after a powercut I have to reset this to get the oven controls back into manual mode. Follow this link to the user guide for your oven and have a read. Re set the timer and should be ok....hopefully! http://safemanuals.com/user-guide-instructions-owner-manual/AEG-ELECTROLUX/B1180-4-M%20UK%20R05-_E
May 08, 2010 | AEG B1180-4 Electric Single Oven
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
I have a Competence B1180, it cuts out after irregular periods of time, although sometimes it may even complete a cooking cycle, if turned off for 10-15min it will re-start, but invariably cuts out again...
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turnig then replace fan. If mains voltage is not present then its the thermal switch.
Mar 01, 2009 | AEG B1180-4 Electric Single Oven
Aeg single oven
You need to reset the timer to manual from auto , that is why your oven won't come on.
Refer to your user manual on how to do this.I can't tell you how as the sequence differs from model to model.
Plz leave feed back for this solution.
Thanks.
Dec 11, 2008 | AEG B1180-4 Electric Single Oven
Need replacement Dial knobs on Oven
Look in yellew pages for a Zanussi dealer, you will need mod number,,serial number, and er number, all of which are on the rating plate found at the front of the oven.
Nov 17, 2008 | AEG B1180-4 Electric Single Oven
Aeg b4101 single oven ,three years od
Sounds like a faulty thermostat.You will need a new one
Nov 07, 2008 | AEG B1180-4 Electric Single Oven
AEG over B1180 Keeps switching itself off after about half an hour
if oven is in fact overhaeting then fauklt will be the thermostat
Nov 05, 2008 | AEG B1180-4 Electric Single Oven
AEG B1180-4 Electric Single Oven Logo
186 people viewed this question
Top AEG Ovens Experts
Sal De
Steve
Samyfam
Samyfam
Are you an AEG Oven Expert? Answer questions, earn points and help others
