Question about Whirlpool LER5636P Electric Dryer
Put belt on dryerg - Whirlpool LER5636P Electric Dryer
    Problem Solver:
  • 8 Answers
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Posted on Jan 09, 2009
Dryer don't turn just make a noise
Posted on Nov 28, 2008
    Genius:
  • 1,198 Answers
If you're really lucky, there's a diagram on the back of the dryer. You still have to open the whole thing up to get the new belt over the drum! The real fun is holding the spring part back while you get the belt on.
Posted on Nov 25, 2008
How to replace blower belt on whirlpool cabrio dryer model wed7800xw0
first put pulley onto blower fan housing i think you have to counter clock turn to put the pulley by hand. put you one hand inside the blower housing and hold the fan then use pliers and tight the pulley. now put belt on motor pulley first then put belt on blower's pulley it is hart to put on so little belt on pulley and use other hand and turn fan from inside so blower's pulley turn and belt get to pulley. last tight the pulley again. turn fan by hand to make sure belt run ok. hope it will help you.
Dec 21, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Tip
Changing inside pully belt
if you have two belts on your vehicle and need to change the inside one , put the edge of belt one pully that has outside belt and hit key couple times (do not start) the pulley and belt on the outside will turn putting the inside belt on inside without removing outside belt , Will leave small mark on belt that you put on But will not hurt it
on Sep 19, 2010 | Chevrolet Blazer Cars & Trucks
Tip
Putting belt on
when putting belt on use a wire tie/pull tie on the transmission pulley and tie the belt to it put belt on motor and gently pull belt on transmission pulley after it is on cut pull tie and turn pulleys and belt to proper adjustment on tranny and motor
on Dec 08, 2007 | Hotpoint VVSR1070D Top Load Washer
I have a powerclean bissell vaccum and i just got a belt to replace, is pulley the little metal part on the side where belt goes because when i put the belt over the metal part and around rotating brush...
You did not put the belt on its proper place that's why it happen. Replace again the belt and put it not over the metal part. Put a mark where the belt belong so that you'll remember it when you gonna instal the belt. A mark like pen or masking tape will do.
Thanks for asking.
Jul 13, 2011 | Bissell Vacuums
Putting on belt
put it around drum,then around motor pulley, then idler pulley with spring attached to, move it forward and slip belt onto idler pulley and release and belt should become tight,then self align belt by manually turning drum before putting unit together
Sep 13, 2009 | Crosley CDE6000 Electric Dryer
Deck belt need to no how to put the belt on
How to install a belt for a poulan riding lawn mower deck S#120403A001222 15.5Hp 38" 5sp
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Motor
service manual should be located inside of unit.
remove the front panel and inside cabinet, taped to the side should be an envoloppe containing the service manual
May 27, 2009 | Dryers
Slipping belt onto motor shaft pulley
On most vacuums, you:
put the belt on the motor,
slip the beater bar thru the belt,
put the end opposite the belt into the frame,
stretch the belt and put the belt end of the beater bar into the frame.
Hope that helps!
Apr 25, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Replacing belt
Put The Belt On The Motor First Then Put What You Can Get Of The Belt On The Other Pulley And Turn It. It Will Give You The Anchorage Needed To Put The Belt Back In Position. If This Doesn't Help Let Me Know And I Will Further Assist You.
Sincerely,
Michael Scott
Feb 10, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Changing the belt
flip over
remove 3 phillips head screws and remove cover
pull agitator roller out of groove opposite end of drive belt area
install new belt by putting loop around silver drive shaft then putting over belt roller
put roller in appropriate grooves( belt will feel stiff make sure belt stays on roller and under drive shaft put cover back on
You are ready to go!
Jan 03, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Whirlpool LER5636P Electric Dryer Logo
380 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
