Question about Sony Playstation 3 (PS3) Console
Tv says no signal on tv with ps3
Ps3
  • 903 Answers
If there is no signal, then one of the cables or wires could be loose, check that all of the cables/wires are connected properly. Then if still not working try changing the av/ext channel that you have it on.
Posted on Nov 16, 2008
Samsung TV Is Not Picking Up A Playstation 3 HDMI Signal
If you are able to connect your PS3 to another TV using the same HDMI cable that would rule out your PS3, if it works.....or
does the PS3 itself have any settings that perhaps need to be set to an HDMI output as opposed to Composite or SCART etc?
Also have a look at the HDMI settings in theh TV menu too.
Jan 10, 2014 | Video Game Consoles & Games
Tv recognizes ps3 through hdmi but ps3 not giving a signal to tv
you could have a loose south bridge chip, you will need to do a re-flow.
also check any small resisters next to the HDMI port.
Jan 03, 2012 | Video Game Consoles & Games
I was playing my PS3 and moved it from my tv upstairs to my tv downstairs. After plugging my PS3 in my tv downstairs, on which it had worked just 1 week previously, my tv picked up no signal from my PS3....
Try this.
Plug your PS3 on either TV. Turn on the backswitch. When the red light in front is on, put your finger on the on/off button in front AND KEEP IT THERE. You will hear some beeps; don't worry about that. Keep your finger on the button until the front power light goes red again. This resets the PS3 video settings. Turn the PS3 on and the TV should pick up the signal.
Hope this helps. Keep us posted.
Jul 04, 2011 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 and change the tv output to the right one it says "no signal only audio" at first i thought it was my hdmi wire but i got a new one and tried that and it still doesn't...
Try the alternative connection, with other TV set. This means change your TV for moment and check it with the PS3. Use AV connection if you have provisions to make sure if your PS3 has video signal. This will ensure you that your PS3 is working fine. If you can't get any signal out, then check your PS3. Other options is, setting your TV's NTSC/PAL system to auto mode for video signal. This function can be done using remote control or user manual can also be a good help.
Apr 14, 2011 | Video Game Consoles & Games
Hdmi no signal to tv but works on another tv
Try changing the reselution on the PS3 to a lower setting when on the TV that is does not work on. Had the same problem and that fixed it. PS3 is sending a signal the TV can not read.
Jan 27, 2010 | Sony Playstation 3 (PS3) Console
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV doesn't recognize PS3
put cables ps3 came with in with ps3 on standby hold power button on ps3 down 10sec and it will reset audio and visual setings
Jan 06, 2009 | Sony Playstation 3 (PS3) Console
I have a Denon 589, PS3 and Sharp Aquos. Using HDMI cables, PS3 to TV directly = great signal. PS3 to Denon to TV= no signal.
ON PAGE 98 OF YOUR MANUAL YOU WILL SEE THE RES OF 1080P ARE NOT HANDLED SO YOU SET YOUR PS3 RES TO 1080I, 720P YOU WILL HAVE PIC FROM YOUR PS3 TO YOU DENON TO THE TV
Nov 27, 2008 | Denon AVR-3806 Receiver
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Sony Playstation 3 (PS3) Console Logo
316 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
