Question about Dryers
Whirlpoool dryer not heating replaced the thermostat
Replaced the thermostat 1 1/2 months ago it heated again but now same problem tumbles but no heat.. heating coil still looks fine
  • 240 Answers
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Posted on Nov 16, 2008
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Hi. DLEX8377WM - no heat...dryer tumbles and there are no errors, but no heat. Happened a few months ago, but started working again.
sounds like the heating element is out, you can disconnect the vent hose turn on dryer and see if heat comes out.
Aug 03, 2010 | LG Dryers
My hoover tumble dryer Hnc175 wont heat up,is still working as normal, just no heat, i have cleaned out the filters and still not working
Heating elements can fail. These are relatively easy and economical to replace. The heating element is not necessarily the culprit if your tumble dryer does not get hot, however. There are thermal overload cutouts fitted to many machines. If they fail, the current will not be passed to the heating element. Replacement is again, fairly straightforward.
Tumble dryers will often have thermostats fitted. A heater control one, and an exhaust thermostat. The first keeps the temperature correct. The second, as its name suggests, monitors the temperature of the exhaust (in case the airflow in the machine is impeded) Once again, replacement is not too much of a problem.
http://www.repairclinic.com/Dryer-Troubleshooting
Please look, at the link above, it will show you how to perform troubleshooting. procedures and repair.
If you feel you don't want to do it yourself, please call a Hoover Tech, and get it looked at. Ask for a "Quote" for the repair, so you get an idea of whats what.
Apr 08, 2010 | Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Hotpoint aquarius tdc32s not heating up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Sep 03, 2009 | Hotpoint TDC32 Electric Dryer
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
Nov 01, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
