Question about Dishwashers
Dishwasher stops and beeps mid cycle
I have put on my dishwasher and it gets halfway through the programme then stops. All the lights except the one relating to the programme it is running light up and it beeps for 10 seconds. It then stops beeping and makes a noise as if draining. Then it beeps again at 3 minute intervals. i had a manual but it has disappeared. help! The model is Proline Logic
eagle338
  • 4889 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
SOURCE: MATSUI DISHWASHER MS160SL. IT STICKS
I have the same problem and have found that it is caused by as you suspected a burned out heater element. they can be purchased on the web for £15.95 at partmaster .co.uk
Posted on Sep 29, 2008
  • 258 Answers
SOURCE: Dishwasher keeps cutting out
Has the door got heavier recently?
Mine had a spring break which fell onto the electrics and shorted them. Unplug and empty it, then tip it up to see if you can see a loose spring. If it is then replace or re-fit the old spring, I have posted instructions and pictures here:
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 30, 2009
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
SOURCE: all 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Posted on Mar 15, 2009
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Jan 17, 2013 | Fisher and Paykel 23 in. DD-603 Built-in...
Dishwasher lights flash half way through program
you will have to consult your owners manual
Jun 07, 2012 | Dishwashers
Halfway though the cycle I get 4 beeps and flashes, I put the dishwasher in test and it found no faults when I tried the dishwasher again it works? fine a few times and the gets the same fault again.
Hi and welcome to FixYa, I am Kelly.
Two things you should do:
1. Check the drain hose from the sump all the way to the sink or disposal connection.
a. Remove the drain hose from EACH connection and check for obstructions.
b. Dis-assemble the Air-Gap by lifting off the cover and unscrewing the cap nut. NOTE the installed position of the CAP as it will only install ONE WAY. Remove any debris in the Air-Gap passages.
2. Inspect the water level FLOAT or water level finger sensor (depending on your model of dishwasher) for either food particulate/blockage or restricted movement up and down of the water level float.
By doing this you eliminate both drain and fill issues unless there is a problem with the inlet water flow supply. This should get rid of the intermittent mid-cycle 4 Beeps.
If after doing the above, the problem persists; just respond here and we can continue troubleshooting.
Thanks for choosing FixYa.
Kelly
Nov 29, 2010 | Dishwashers
MY GE Triton GSD5200 just stopped mid cycle...it is beeping and the normal cycle light is blinking. What is wrong?
I had the exact same problem. It was near the end of the cycle and it just stopped and then started beeping. I opened the door, and something seemed to pop. Looking at the mechanism, I'm thinking that the Jet Dry dispenser had gotten stuck somehow, and fiddling with the door loosened it. If it gets stuck again, I'll probably just remove it since I never use Jet Dry.
Jul 03, 2009 | GE 24 in. GSD5200 Built-in Dishwasher
Miele dishwasher Advanta Series. Once the cycle is done the beeper continues to beep until someone opens the dishwasher and the beep then stops. Is this programmable?
the washer starts runs for 10 mins then beeps and beeps all the lights turns on in the programing panel inside HELP
Jun 22, 2008 | Dishwashers
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Indesit Di 67
Tilt your washer forwards. Water will leak from the front but once this has cleared your dishwasher should be ok again. I paid an engineer to come and tell me this. If your dishwasher is not completely level this can sometimes happen. Hope this helps.
Oct 18, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
Dishwashers Logo
189 people viewed this question
Top Dishwashers Experts
