Wondering if a fuel cap change is the fix...
Code PO455
EVAP Control System Large Leak Detected
Possible Causes:
Aftermarket EVAP hardware non-conforming to specifications
Canister vent (CV) solenoid stuck open
EVAP canister purge valve stuck closed, or canister damaged
EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged
Fuel filler cap missing, loose (not tightened) or the wrong part
Loose fuel vapor hose/tube connections to EVAP components
Purge sensor or FTP sensor is out of calibration or has failed
I would say that your gas cap is a good place to start.
SOURCE: ford focus, 2000 zx3 code p0455
your engine code means "big leak" in the evap control system, this system has alot of pieces, but you are looking for a vacuum leak most probably, look at your vacuum hoses, and refer to the vacuum diagram stuck under your hood for routing, see if you have a bad hose, or disconnected hose some where. these are small vacuum hoses that attach to the purge valve, air filter housing, and charcoal cannister. let me know what you find.
Testimonial: "Found the leak on the purge control valve. The hard plastic vacum line had holes worn in it from vibration. Thanks"
SOURCE: obd code po455 2000 ford f-150
P0455 indicates that the Evaporative Emission (EVAP) control system
detected a large leak or no purge flow. has nothing to do with the
exhaust, unless, the leaking hot exhaust gases burned up a hose of some
other part of the EVAP system.
Thanks.
Testimonial: "yes this helped,but now i need to know how to fix it or what to look for"
