Question about Philips SA5125/37 MP3 Player
It wont turn on
I plug it in and it says do not disconnect then it says OK but it does not turn on
  • jjaass Nov 30, 2008
    i plug my mp3 in the computer to charge it but when i took it off it want turn on
  • 8,596 Answers
May be hardware, but do the following to be sure:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Dec 12, 2008
Ok so we replaced the ac compressor with a bypass pulley and the car cranks but wont turn over. what could the problem be ?
Did u disconnect any wiring when you replaced the pulley...if so, did u check all the wires/plugs to make sure everything is conne ted properly
Oct 01, 2013 | Cars & Trucks
My vw passat 2000 wont start sometimes and when it does start and I give it lots of gas the revs seem to drop and it loses power, but if i accelerate slowly it seems ok, also after driving for maybe 10...
sounds like you\'re not getting enough fuel; disconnect the fuel line under the hood and put it into a container and crank the engine or just turn on the ignition for a couple of seconds to activate the fuel pump; it should be pissing like a race horse; if it\'s not, then you have a clogged filter or a weak pump.
Mar 03, 2013 | Cars & Trucks
My 1999 expedition wont start. your guy said it may be the pump, the the fuel shut off switch then the relay. not any of the above. whats the problem?
ok first check for fire at spark plugs if there is no fire then your problem could a sensor could be a crank or cam sensor or disconnected wire, check all your fuses, inside engine compart. and (inside the car) you need 3 elements for the engine to run, fuel,air and fire, if one of those is not present then your car wont start, it will turn over but wont run.
Apr 07, 2011 | Ford Expedition Cars & Trucks
Archos 504 wont turn on
Disconnect the battery for few seconds and replace back again, then turn on. I had the same problem and that was what I did.
Sep 17, 2009 | Archos 504 500870 Digital Media Player
My insignia wont turn on please help!!!!!
I always have to hold the button for at least ten seconds.
May 15, 2009 | Insignia NS-DV2G MP3 Player
1998 jeep wrangler sahara brake, tail and turn signal wont work
Did you go off road in the mud or woods?If so the connecting plug where all the connect probably has gotten disconnected.I think it is near or between the fuel tank and rear bumper.
Aug 30, 2008 | 1998 Jeep Wrangler
Ipod wont show up on itunes
go to applications then utilities then open disk utility
on the on the left side all the hard drives will be listed. click on your ipod then click erase, look here click "erase" and then "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
PC:
go to start, my computer. in the new window your ipod's name will apear right click then click format. make sure that quic format is checked and then click "ok". when it is done disconnect the ipod, open itunes and reconnect the ipod. itunes will tell you the ipod is corrupted and i needs to restore it. click ok and then wait for it to complete the restore.
Feb 19, 2008 | Apple iPod nano
Frozen screen
my ipod wont turn off or nothing i tried downloading music like i always do and my ipod shows that picture of the plug and it says under it "ok to disconnect" it wont turn off or nothing
Dec 27, 2007 | Audio Players & Recorders
Philips SA5125/37 MP3 Player Logo
63 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
