On off button
My on/off button on my Compaq x1000 Presario lap top computer is stuck/gammed and i can not turn my computer on. What can I do? I had to shut down the pc by pressing the power button for 10 seconds. Now I can't re-start it as it seems that there is no resistance on the power button when I am pressing it?
  • 4,806 Answers
Remove the battery and try to start it using AC power, if the button is stuck or jammed try to free it using a small flat headed screwdriver, take care to be gentle not to damage the button, if the machine is still under warranty, sent it for repair
Posted on Nov 16, 2008
I change the battery on my lap top. The Lap Top don't recognize the new battery I have a compaq presario x 1000.
If your Hp Utility program have already installed, run a battery maximizer. but if it doesnt, download it from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=321852&prodTypeId=321957&prodSeriesId=321850&swLang=8&taskId=135&swEnvOID=1093
Choose your Operating sytem and download.
NOTE: Using Depleted battery for long period time may freeze power management console, so in order to use a new battery you should calibrate the battery. or try Charge it for 8 hours staright.
Cheers
Aug 23, 2011 | Compaq Presario X1000 Notebook
Describe how to turn on the wireless network card on a Presario X1000
There is a button at the front. When the system is ready, you press it and a little blue light should come on. Good luck.
May 21, 2010 | Compaq Presario X1000 Notebook
Dark dark screen
that rubbery nipple when its pressed in is what allows the screen to go into sleep mode. Sounds like it might be stuck halfway in between. Go ahead and try to take out the top cover with the rubbery nipple on it. See if the screen lights up like normal, if it does then you know the rubbery nipple is the problem and just needs to be readjusted so it doesn't get stuck.
If it still stays dim then its either the lcd or the inverter that is bad.
Jul 04, 2009 | Compaq Presario X1000 Notebook
On off button
Same thing happened to mine. I took it to a tech to fix it.
Oct 01, 2008 | Compaq Presario X1000 Notebook
Power button
If it is the plastic button that is down and won't return, you might try using some silicone lubricant available from hardware or auto parts stores. Silicone is a dielectric so it won't bother the electronics and might free the button.  I wouldn't recommend spraying the pressurized lube into the button recess but rather into the spray can's cap and then using a denuded Q-tip to dab a few drops around the periphery of the button. The carrier of the lubricant may attack plastic but is very volatile so you can let that part evaporate leaving only the silicone.
Broken power button
They Have one for sale On ebay if you need..
Look here for your compaq presario X1000 power button bezel
http://cgi.ebay.com/APCL312M000-compaq-presario-X1000-power-button-bezel_W0QQitemZ230260679776QQihZ013QQcategoryZ60265QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope it helps.....
http://www.wnycomputerpro.com
Jun 11, 2008 | Compaq Presario X1000 Notebook
Compaq pressario X1000
yes. when the switch is turned on it activates the built in wireless card in your laptop. you can then connect to a wireless router
Jun 10, 2008 | Compaq Presario X1000 Notebook
My Compaq Presario X1000 doesn't recongize my camcorder via firewire port.
It may be the problem with driver. Your OS may not contain the proper driver.Like in windows service pack 1 do not recognise some camcorders. either upgarde to service pack 2 or download proper driver from manufacturers site
Apr 21, 2008 | Compaq Presario X1000 Notebook
Curser frozen
did u turn off ur touch pad.
did u check by useing an usb mouse
Jan 04, 2008 | Compaq Presario X1000 Notebook
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
