Question about Dewalt 18 Volt Compact Drill Kit
Torque ring stuck in hammer on my dewalt dc935
Only used the drill twice so not sure if there is somthing you press to release this.
  • krauscouf Nov 16, 2008
    The torque ring on my drill will not turn to hammer or straight drill just the clutch number settings.
  • budasmail May 22, 2009
    same problem some imes what to do?
  • 3 Answers
Remove the spindle housing ,turn the collar spindil, if i d'ont turn replace 629828-00 spindle & clutch assy.
if i turne check the transmission 613237-00
Posted on Feb 16, 2009
Type your problem for a solution...
I'm answering without knowing which model you have but, there are some Dewalt drills that will go into hammer and/or drill mode only if the speed selector is in 2nd gear. The torque settings are accessable only in driver mode. Short of that you may have broken parts in the transmission that can only be repaired by replacing the transmission.
Dec 28, 2011 | Dewalt Drills
Dewalt xrp stuck in hammer mode cant move selector to drill or number selections
I am assuming you are talking about not being able to move the "Mode Control Collar" and unless you can get it out of hammer mode, you will not be able to change the torque collar either.
If you feel comfortable taking it apart AND its no longer under warranty, my best guess without seeing the tool will be part# N026313 Gear Case Assembly. It costs about $80.00 US
Hopefully its under warranty, if so you can go to
http://servicenet.dewalt.com/ServiceCenter/Search
to locate nearest service center.
Good luck
Sorry I wasn
Apr 29, 2011 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
I have an 18 volt hammer drill combo drill. I
Do the same in reverse, if possible. Also, you could use two channel locks as most of those chucks have two rings, the narrow one towards the drill itself being attached to the motor. However, make sure the screw inside the chuck is tight first -- I've seen those back out and block chucks open.
Mar 06, 2010 | Dewalt 18 Volt Compact Drill Kit
Drill works fine but wont engage hammer. the torque ring goes from 1 to 21 ok but i cant engage the drill or hammer setting
On my DW988 the ring would go past 21 a couple of clicks to a symbol that looks like a yellow T and that would be hammer mode when I press down to drill.
Nov 18, 2009 | Dewalt DC925 Cordless Drill
How to switch to hammer on dc935
Turn the black clutch adjusting collar all the way to the hammer symbol. It will be just past the Drill symbol on the collar. Then when you press the bit against the material you will feel the vibrations.
Oct 14, 2009 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18V XRP Hammer drill, stops on torque in drillpositio
The brushes might need to be replaced. You can find them on Ebay and are easily to replace.
Aug 01, 2009 | Dewalt DC927KL Heavy Duty 18 Volt Cordless...
Dewalt DC925 Clutch Ring Jammed
if your in hurry & away from the service center all you need to do is just loosen the 4 screw that holds the clutch housing & set it # 1 & back to drill mode couple of times. do not remove clutch if your not sure co'z its got tiny needle bearing on front of the transmission.this is just a temporary fix . it may happened again.
Jul 03, 2008 | Dewalt 18 Volt Compact Drill Kit
Dewalt 18 Volt Compact Drill Kit Logo
1,083 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
