Question about Acer AL2216WBD LCD Monitor
Acer 22 inch monitor shuts off with indicator still green
I go on the internet or work offline and my monitor shuts off with indicator light still green and no picture ,it was fine for 6-7 months it did not do that and now for that past few months when the screen turns black I just turn in off and on again and it works for 5-10 mins and turns black again and I keep in turning it off and in and it works for a bit and over and over again I adjusted the screen resolution to higher and lower and adjusted the NVIDIA Geforce 7350 Le as well to better performance and that did not seem to work and also adjusted the cables from DVI-D to VGA and that did not seem to matter either , so I am totally out of idea's can anyone help me ??
Thank you
Jenny
  • Anonymous Apr 08, 2009
    My monitor was fine until it started flashing on & off & then went black. I turned it on & off again & it comes on for a minute & then does the same thing.
  • 298 Answers
The computer may be programmed to do a monitor shut off after lets say 20 minutes. This is a power saving feature of the operating system. Open Power Options under Control Panel.. select the drop down combo box that says "Turn off monitor" : set it to NEVER.
Posted on Mar 15, 2009
Me horn and indicators dont go. checked fuses and they are fine. dont know where to start.
horn check it works as they can go, relay is probably gone for the indicators. its usually a green relay, but if its original it could be any color. they not on the same wiring as each other.
Dec 13, 2017 | Electronics - Others
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
On my Flatron W2230S, the power on LED do not light on. Though the monitor works fine. The Poer Indicator option in set up in "ON". Any Clue?
I have the same problem after 6 month of use. It dont bother me too much but it would be nice to know what is wrong :)
Sep 01, 2011 | LG 22" FLATRON LCD Monitor
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
The power comes on and then turns off and the front green power light blinks.
There is a small IC in the power supply section,
not the IC regulator that's the problem.
Jan 06, 2010 | Philips 32PT6441/37 32" TV
I have a Philips 170S4. On startup it displays the memory check fine. Then everything goes black, the green light indicating the monitor is still on is still lit up. I can only JUST see some pictures on...
did you adjust the brightness, also in windows settings?
pls check with another monitor ,also you can check monitor with another pc or laptop
try with reset the monitor settings
also change the resolution and display frequency
Oct 03, 2017 | Gateway FPD2275W LCD Monitor
Daewoo monitor F257 not working - no picture - light is blinking
-Possibly due to surge.
-Get new one.
Good luck
Mai
Oct 06, 2017 | Computers & Internet
Monitor will not turn on
6 months old Huh Back to Dell then - first check out their Technical Support Team on the web site
May 27, 2007 | Dell E177FP LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer AL2216WBD LCD Monitor Logo
296 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
