Question about Kaz Sesame Street Elmo & Friends Humidifier - Blue
My humidifier isnt working properly, it is not using any water
I have the sesame street humidifier that I just purchased and im having a problem with it. I got it out of town so im unable to return it to the store I bought it from so im kind of stuck. It runs, you can hear the moter running and it blows the air, the problem im having is no water is being put out with the air. Ive let it run for 2 different nights and the water level never changes. Ive checked to make sure the top is sitting in the bottom tight and changed to a different filter and still nothing. Is there somthing else I can try?
  • 1 more comment
  • ntritsarolis Nov 25, 2008
    I have the same problem let me know if you figure it out.
  • newbob323 Apr 10, 2009
    HCM Model 890...Mine actually built up a nice group of molds. Little black molds all over the inside of the water tank. When I took out the filter it too had a large black mold the size of a police badge on the inside. When I tried to pick it up. It fell apart. I didn't get a chance to dry it out. It had to be cleaned and didn't want to be cleaned.
  • handyman1971 May 22, 2009
    I am returning mine ASAP. This is not a very child-friendly product (despite the pretty Sesame Street logo). I had it set up in my baby's room and noticed an odour after a couple of weeks of operation. When I disassembled the unit, I noticed mold in the base (near motor/fan). There is obviously a major flaw in the design and my intent is to get tis product off of the shelf. I suggest to everyone to use cool most humidifiers wher you can see all of the fan/motor components and you will be able to spot mold issues easily.
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 187 Answers
You need an Ohm Meter to check if your motor will take power. I just took mine apart after letting it dry out "Over-Night" (which = 4 days!). Then I placed a hairdryer (warm setting) on the humidifier vent. for about 45 minutes. You know what happened? Nothing! So I need a new motor that\'s all. Everything else is solid state (switches/lites); so it CAN get wet. But not the motor. You would dink Zey would invent an electric motor that can get a "Little" wet...Darling!
Posted on Jan 08, 2014
I have the same product, but am missing the removable tray. Do any of you still have it and want to give it to me? I have spent so much money over the years on humidifiers and I just want one to last me. I called the company and they do not have any!
Thanks,
Beth
Posted on Mar 02, 2011
I just got the same humidifier. It comes with a three year warranty. Their number is 1-800-0457 there return address is Katz, Inc. Att: Returns Department 250 Turnpike Rd. Southborough, MA 017772. Good luck
Posted on Jan 23, 2009
Make sure you soak the wic with COLD water and don't ring it out. Make sure when your putting the tank back in that you don't spill any water into the fan vent. If you get even a splash into the vent, it makes that awful loud motor noise. If this happens just let it dry out on it's own(over night). Also try cleaning the wic tray. It tends to get slimmy from the water sitting in it. If you ever see that your tank is empty, wet your wic when you refill it. Make sure you rinse and wet the wic EVERYTIME you refill the tank. The wic dries out fast and can start smelling pretty bad if you don't rine it regularly.
Posted on Dec 18, 2008
How do I clean this humidifer? I have the sesame street elmo and friends cool mist humidifier and I cannot find the manual for cleaning instructions. thank you
The outside you can clean with warm soapy water. The inside can be flushed with a 50/50 solution of White Vinegar and Bottled Distilled Water. Fill the tank and run the unit until the tank is almost empty. Pour out the remaining solution and fill the tank with more of the Bottled Distilled Water. Operate the unit for 30 minutes and the previous solution should have been flushed out by then. I would recommend using Bottled Distilled Water all the time rather than tap water. As tap water has a lot of minerals in it that can cause calcium scale and clog the unit.
Hope this helped you.
Apr 19, 2011 | Kaz Sesame Street Elmo & Friends...
Do you fill with cold or hot water for vicks warm steam humidifier
im pretty sure you fill it with cold water...at least thats the direstions for when you use the vicks medicine you can add in...works great by the way
Feb 28, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I have a healthist humidifier model 4100.. I purchased my humidifier on 12/26/09 from Raindew pharmacy. So far I had no problem.But today, when I plugged the apparel, nothing haened, the motor is not...
If you've been using tap water, then you likely have hard water deposits (scale) on the heating element, which will eventually cause it to stop working. Try cleaning it with an overnight vinegar soak, or whatever is suggested in the manual if you have one. Once most of the deposits are gone, it shold work again. In the future, this will not happen if you use distilled (not to be confused with filtered) water. Good luck!
Feb 13, 2011 | Kaz 4100 1 Gallon Humidifier
I have a aprilaire 112. How do you test the solenoid valve to determine if it working properly?
without using a meter? OK take the water line loose from the humidifier that connects to the solnoid. Turn the humidifier on or raise the humidity and water should flow. Keep in mind that if wired correctly the humidifier will only work when your furnace is running although some can be wired to bring on your furnace. You should hear or feel the click if no water comes out you may have no water flow as these valves are pretty durable and seldom fail
Dec 11, 2009 | Aprilaire 700 Humidifier
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Too much water wasted
The oriface is sized for the proper water flow for the model you purchased. If you are dissatisfied you could throttle down on the saddle valve to restrict the water flow to the unit.
Good luck
HVAC Teacher
Jan 31, 2009 | Aprilaire 600 Humidifier
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
Quiet comfort humidifier not working
unplug it for a 1 minute and make sure that the water tube isnt clogged up...it will prevent water from flowing thus displaying "F"
Aug 27, 2008 | Kenmore 14410 Humidifier
Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Dec 24, 2007 | Aprilaire 700 Humidifier
Kaz Sesame Street Elmo & Friends Humidifier - Blue Logo
1,119 people viewed this question
Top Kaz Humidifiers Experts
Kory Ronning
ray gallant
Are you a Kaz Humidifier Expert? Answer questions, earn points and help others
