Vizio VO370M LCD TV Logo
matthew audette Posted on Apr 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Channel up and down function does not work on set or remote
Anonymous
Level 3:
Top Expert:
  • Vizio Master 14,553 Answers
  • Posted on Apr 25, 2012
Anonymous
Vizio Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718605
Points
48227
All TV sets use a microprocessor for this--both the buttons on the set and the the remote end up at the same place--in most cases the buttons on the set have priority over the remote.
Only a few possible reasons for this:
The most likely and simple one is the set has a lock out feature so channels cannot be changed--owner manual or a call with the model number to (says Vizio here) would resolve that.
While on phone if no lockout exists describe problem and see if its a known issue with this model.
Its hardly likely a problem with the remote as front buttons would still function--
This if no lockout or even a hard reset exists leaves a Microprocessor problem which since not parts but circuit boards are sold--going to have to replace a board
I really think to solving this is is there a lockout or a hard reset that should cure this?
3answers
How do i change the source on my emerson tv without the remote
Few, if any, modern TVs provide the option to access menus without a full function remote control - that excludes the majority of universal remotes...
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
1helpful
What is the code for LG 47la860w to work with my Sky + hd remote Control
0392,0390. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Got a Sanyo DS25320 and using a universal remote. The screen is blue and says Video and when I hit menu it only gives me the option of auto/ manual/ game or language, can not get to the other selections....
The tv universal remotes are having very limited options in functions and tv universal remotes are only work correctly are like buttons power on/off volume up/down and channels up/down.Menu button and a Video setting option modes functions setting are another story all together.These two functions Menu button and Video setting modes funtions will not work correctly in any tv universal remotes.Because these Menu and Video setting modes are belong into the internal setting of the tv itself.It will only work correctly with the tv original remote only.Try website like Remotes.com to buy the tv original remote to use.
2helpful
RCA TV model F27252GY. Don't think I have original remote. Need to set to input or video channel to use my new DVD. How do I do this?
You can try channeling up or down to get to channel 99.Rca in the past has used this to get to the video input. If this does not work you can buy a universal remote. In most cases, after programming the universal remote the major functions such as channel select, volume control and input select will work.
I hope this helps.
Skyassoc
Why does every button work on my universal remote after i program it but the channel up and down
Universal remotes alway have somethings missing functions to comparation to the original remote.Well,ur universal remote don't have channels up and down functions.Try website like Remote.com to buy an original remote.
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
6helpful
2answers
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
