Question about Samsung Refrigerators
Refrigerator freezing up and fan catching
Samsung DA99-00494V
Refrigerator internal fan starts to catch ice that has built up.
Ice also builds up between water holder in Fridge and rear casing behind Drawers.
  • 108 Answers
From your information Bill it seems the defrost system has failed. There are several componants that could cause this. First check the defrost heater which is located on the evaporator. You will need to pull the plug and let the ice melt completely first. Store your perishables elsewhere.
With an ohmmeter, check for continuity across the defrost heater. With all due respect, if this is confusing you need to call a service tech. If you have continuity across the heater, check the defrost thermostat which is a round disc fastened to the evaporator.
Finally, look for the defrost relay. It should be found somewhere on the lower rear of the refrigerator. Check for power to the relay, and on the outlet side. A wiring diagram located on the back of the unit will help you find the correct wires. All of these parts should be available from your local refrigerator parts supply, or check with Samsung online to order. Be advised Bill that this is not a simple repair, but if you have some electrical understanding, you can do it.
Ray
Posted on Nov 16, 2008
  • dennis bogush Feb 25, 2014
    how do I access the equipment to check it
Not freezing enough
You might have ice building up on your evaporator coil. That ice serves as an insulator and prevents the internal freezer temps from going down to design parameters. The ice buildup is caused by the defrost mechanism not working - check the timer or the defrost heating element.
Jan 07, 2014 | Summit 12.6 Cu. Ft. Frost Free...
Why is ice build in my frost free/refergirator, and water dripping into refergirator?
Your Kenmore may not perform well in the garage environment. Since it isn't practical to move it back inside, you may have to abandon the idea of having a second operating unit.
Dec 15, 2013 | Refrigerators
Samsung double door (fridge) the fridge cooler part is iceing up, the fan switches on and off you can hear it is catching on ice
There is ice build-up behind the plastic casing. If this is
not removed it will get worse, If you are pretty handy you can remove the white
casing at the back of the fridge and remove the excess ice. If not turn off fridge
and let it defrost completely. The alternative is to call Samsung if still in warrantee,
if not in warrantee they will charge you to compete this and it will not be
cheap!!
Aug 18, 2013 | True Freezer Glass Double Doors Top Mount...
I have a build up of ice in the fridge compartment and inside, the fan is catching it as well.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Mar 31, 2011 | Samsung RS2556 Side by Side Refrigerator
The ice maker in my samsung fridge is putting too much water into the ice tray thus dripping water into the ice compartment and freezing all the ice cubes together and dripping through the outlet
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray is supposed to catch the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Jul 17, 2010 | Samsung RS2578BB Side by Side Refrigerator
Water accumalating in the bottom of the fridge.
A common problem. All modern refrigerators have an automatic deicer. The heater kicks in, then MELTS the ice in build up in the freezer for a short period before freezing again. This water drains either in the fridge or out the back to the catch tray. Simply pull out the bottom drawers and clean the clogged drain hold where the water can drain and evaporate in the catch tray as it is designed to.
Mar 14, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Water puddling in bottom of freezer which freezes
Tool needed: Screw drive with the insert tips can be used to remove screws use the end of the screw driver with out a philips bit or flat tip inserted. Remove frozen food to camping coolers igloo ice chests or coleman ice chests or a freezer in your home . Remove all racks and baskets to expose movable panels at the inside back of the freezer compartment.
Notice the 1/4" hex nuts remove the screws holding the panels at the back wall. Clear built up ice carefully. You now can take out the panels and expose the fan and cooling cool that creates the cold temperature on the freezer side.
Near the bottom is an aluminum U shaped pan with a shallow funnel indentation at the bottom. Clear ice from the funnel pan and inside bottom carefully. Sharp objects break ice nicely and can pierce the interior surfaces . Look under the cooling coil and at the back wall is a screw holding this soft metal catch pan in place. Remove the screw and carefully tip and slid out the catch pan tray. You now have access to the drain hole that is frozen closed or clogged. Place a large towel in the bottom of the freezer area to catch water. Pour hot tap water a half cup at a time into the drain area. Do not use boiling water the plastic inside a refrigerator or freezer can not tolerate high temperature. I have melted a freezer compartment in a GE with a hair dryer. Remove the water with a clean reag and add more warm or hot water repeat until the drain allows water to flow. stop adding water or the evaporation pan under the refrigerator will over flow.
Check the refrigerator about once a year for the freezeup problem or keep an eye on the bottom of the freezer looking for the build up of water frozen on the inside floor. The other solution get a new refrigerator.
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
FREEZER SOUNDS VERY NOISY
It could be the fan is bad or that it is hitting ice. If the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal. Avoid 'windowshopping".
Dec 22, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
467 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
