Question about M-Audio M Audio Studio Pro 3 Powered Desktop Monitors (Pair) Computer Speakers
Speakers sound blown out
Suddenly my speakers sound like they are bown out - like someone turned the bass up really high on a very cheap woofer. I've been using them through the headphone port of my presonus firebox. This could have been my mistake and the cause of the problem - I don't know. I have tried them through additional sources with the same results.
Had same problem, tried windows media player instead of media player classic, turns out its a codec issue.
Posted on Dec 29, 2007
SOURCE:
Why is there no bass?
Not much info to go on here, but my thought would be you have blown the woofers in the speakers, or the crossover in the cabinet, that separates the highs from the lows. . If you can touch the woofers with your hand, spread you hand wide over one, and try to move the cone. If it makes a scraping sound , the speaker is blown. If not,the crossover is probably damaged.
May 05, 2014 | Cambridge Soundworks Audio Players &...
WHEN YOU PUSH DOWN EVENLY ON THE SPEAKER ITSELF...IT JUST SUDDENLY GIVES-WAY, WITH A KIND OF POP. DOES THIS MEAN THAT THE WOOFER IS BLOWN??? AND IF SO IS IT POSSIBLE TO REPAIR THIS TYPE OF PROBLEM? ...
The first thing to do is to check the resistance of the voice coil. Get an ohm meter & place one lead on each of the speaker terminals. If a value of 0 ohms results, or no reading at all, the voice coil is blown.
If you are pressing in, and suddenly gives way, my guess would be that the excursion of the speaker was too grand (common with car stereo, everyone loves bass) and the wires that wrap around the voice coil of the speaker were broken from the speaker inputs.
It is possible to recone the speaker, but by the time you track down a recone kit (highly unlikely that it is even available) you would be rather deep into the project.
Long story short:
check the speaker terminals with an ohm meter. If you get a resistance, they should work with free woofer movement. No resistance = blown woofer.
Mar 17, 2011 | Lanzar MAX10D Car Subwoofer
Only the front left and right + sub woofer work. the front center and two rear speakers do not work. when i set the options to speaker fill all the speakers work but the bass suddenly goes very weak. why?
This is your surround sound system they should work when you are watching a movie with surround sound. make sure that you polarity are correct on all speakers.
Nov 28, 2009 | Logitech X-530 Computer Speakers
I have a pair of mackie srm 450 and one swa 1501 the bass output in one of the 450s has no sound. i hear sound only from the high frequency part of the speaker
you have one of two problems.1) the woofer is blown(most likely) or 2) the crossover is fried(rare). Take the woofer out and press on the speaker cone(softly). If there is a scratchy feeling when you move it or if it doesn't move at all, you'll either need a new woofer, or get that one reconed.
good luck.
Dec 04, 2008 | Mackie SWA1501 Subwoofer
Speakers have cracking especialy with dee bass sounds
You may not like this but in the audoi/video community bose is overpriced middle of the road HTIB broduct. you can get a better system for a LOT less than what you payed.
As for the speaker issue' they are bottoming out because those drivers that they use AKA. The cheap $35.00 woofers and $2.00 tweeters were not meant for the application that they use them for, they are the same drivers that they use in their bookshelf speakers and are being ovelrloaded by the extreme LFE and HF content that is being fored through them.
I am surprised the woofers havent blown by now.
Jun 27, 2008 | Bose Lifestyle 28 System
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
Speakers stop playing when bass is turned up
may be there is problem with your woffer spk bcoz bass is contrlled by woofer see if you can see the spk cone is not tear or it is damage. bye
Sep 23, 2007 | JBL CREATURE II Computer Speakers
Creative gigaworks s750 bass turning off
switch off the spk and check the woofer spk audio cable connection is it loose or something .swith it on and just connect only your woofer and see r u geeting any sound from it . bye
Sep 16, 2007 | Creative Labs Gigaworks S750 Computer...
584 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
