Question about HP OfficeJet 7410 All-In-One InkJet Printer
I cant reach the paper that is jamed what do i do
  • 1 more comment
  • hfulgham Nov 16, 2008
    yes in rear at the paper feeder but torn so i can not reach it and do not know where the paper feeder is and tried several times to feed paper through hoping it would push the caught paper through
    you rock! thanks so much it's fixed!
  • JDTec
    JDTec May 11, 2010
    where is the paper jamed at? in the rear?
  • 104 Answers
Have you been able to take the door off at the rear?
If you haven't tried this before, there is usually a door at the rear of the printer, with two circular recesses. Push the latches in and lift the door out, then see if you can reach some or all of your stuck paper.
Posted on Nov 16, 2008
  • eecom Nov 16, 2008
    :) Excellent news! Thank you very much for the feedback.
  • HP Master
  • 4,338 Answers
Remove the rear access door to clear the paper jam
  1. Press the Power button (i cant reach the paper that is jamed what do i do - c01324469.gif ) to turn off the product, and then turn the product so you can access the back of it.
  2. Disconnect the power cord from the back of the product. You must disconnect the power cord so the paper-feed rollers can turn freely.
  3. Remove the rear access door. Press in the tabs on the rear access door, and then pull it away from the product. Gently pull the paper out of the rollers.
  4. Reinstall the rear access door.
  5. Reconnect the power cord to the back of the product.
  6. Press the Power button (c01324469.gif ) to turn on the product.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&product=391194&rule=26368&lang=en#remove_the_rear_access_door
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 17, 2008
My canon ir2016 copier comes with blank paper when printing and the paper jamed before it reaches the paper pick up roller
Check very carefully it sounds like something small is caught in the paper path, probably a small piece of paper.
Dec 11, 2014 | Canon Office Equipment & Supplies
I HAVE A REPEATED PAPER JAMES THE PAPER WILL NOT PASS THRU NO MATTER WHAT SIZE SHEET I USE
check for breakage or resistance in the paper path. does the paper reach the fuser module? or does it get stuck while exiting? clarify please.
May 23, 2011 | Xerox DocuColor 12 Color Copier
Had message paper jamed pulled out paper now cant get the power to come on
Disconnect the printer from the power supply for 30 seconds, connect again to see if work. Make sure you remove the jam paper completely.
Apr 30, 2011 | Lexmark X3470 All-In-One InkJet Printer
Printer Jam in HP CM 312 nfi mfp in output tray path. Can see paper from the front but you are supposed to be able to clear from the back. No one seems to be able to figure out. Please help.
Hi there.If the jamed paper didn`t reach the back of the printer then you need to open your front cover and pull out the toner cartridge and you can pull the paper from there.Grab the paper in the middle and pull it out slowly or you may broke the paper and the things will get serious.If the paper has reached the back of the printer, open the back cover of the printer, pull down the green levers of the fuser to release the paper and pull it out.If you need any futher help please replay.Thaky for using Fixya!
Dec 14, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper james during scan,clicking sound in upper
Clicking sound is not a healthy sound, check if any gear wheel is damaged. Is the tray moving up properly? There are a few sensitive parts like the clutch, gears etc. If you cant fix it please call a trained technician, so that damage is minimal.
S. Mohan
Nov 04, 2009 | Canon CanoScan DR3020 Path-Through Scanner
Paper jam on my ESP3 printer. How do I get the
Go to www.kodak.com/go/itg and select all in one printers and then paper jam as your problem. they will give you step by step instructions to resolve the issue. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printer for you free of cost as all the esp-3 printers are in warranty as of now.
Aug 07, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper gets jamed on the upper feeder and cant remove it.
put it off and on and repeat until the jammed paper comes out. Pull the paper out as it comes out.
Jul 15, 2009 | HP Hewlett Packard LaserJet 3052 Printer
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
Paper Jam
Open all the doors and remove any removable assemblies. Use a flashlight and some compressed air to try to locate the paper shard.
Jan 15, 2008 | Brother Multi-Function Center MFC-240C...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
55 people viewed this question
Ben Johnson
