Question about Bissell 1672 BIGgreen Wet/Dry Vacuum
My pump runs but won't pump
My pump has run dry
  • Anonymous Nov 28, 2008
    the pump hums but won't pump. This happens almost every time I bring the cleaner out but this time I can;t get it to work at all.
  • 18 Answers
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Posted on May 25, 2010
How to get solution out of rainbow shampooer
It is always best to run hot clean water through the wash cycle to flush out all soap when finished. This helps to prevent soap from drying in the lines and pump. You can also try this to help free a pump that is not working correctly.
Our tech. team is available if needed... Contact Us
RainVac
May 24, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Aqua mate II wont spray water
RainVac
May 02, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have a Rainbow Aqua Mate II and have it all hooked up but water will not come out of the white tank. I am using the trigger but nothing is happening.
It sometimes takes a good soaking with water in the tank for a while. Maby a Week or longer, and it also takes a little running time. Not more than 10 minutes at a time, then cool for 30 minutes inbetween runnings, for the water to pump out of them. Do not even hook up any hoses, until it pumps water.
Thank you,
Ralph
Nov 23, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Water does not spray out
make sure all hoses are hooked up and pump is running
Nov 19, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Water line routing
The biggest prob with Bissel is not pumping soap. Becuase if you don't run hot water through this tank the soap will dry and clog after cleaning and storing. Before taking it apart try running hot water through the solution tank and help break up the residue, best of luck. Steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum: I have a Bissell 7901-1. I need to replace the pum...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
78iiry
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Pump runs but won't pick up solution from tank
I have the same problem. Pump runs a little sluggish but water does go up the siphon tube.
CR
Jul 15, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
I have a proheat 2x, and the pump will only spray water for a few seconds when unit is turned on, then nothing. The attachment is the same way. I think this is the pump failing, and the unit is only over a...
I just had my pump replaced for $66 and the repairman said this unit is notorious for this problem. He had 6 other units in his shop when we came in. Make sure you keep your clean water tank FULL, as he said the pump fails as soon as it runs dry.
Apr 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Bissell 1672 BIGgreen Wet/Dry Vacuum Logo
157 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
