Question about Refrigerators
GE Refrigerators - Water dispenser not working ? I
I have the same problem that has been perhaps posted on your site before : Generic problem for all GE Refrigerators - Water dispenser not working ? I have replaced the water filter inside and checked the water comnection to the pipeline - all are great ! Even the ice maker is just fine. But the water dispenser is just not letting out even a drop of water !What do I do ??
  • Anonymous Dec 26, 2008
    My problem is similar. But when I hold the water dispenser, after about 5-10 seconds, I get a puddle of water on the floor.
  • 3 Answers
Remove front grill then disconnect the water line at the quick connector. Place line on right side into container and push lever for water. If no water flows the problem is a solenoid on the left side of the back of refrig behind lower panel. If water flows into container the problem is related to freezing of the water line in the freezer door. GE fix is a $500 plus door replacement. Thaw from back of door behind the dispenser with hair dryer (do not get plastic too hot). Cheap fix is to insulate back of door with insulation such as a foam sleeping bag mat or the foil and bubble wrap type of ducy insulation
Posted on Dec 04, 2008
Water is not dispensing
Generic possibilities: 1) clogged filter - replace if needed, 2) defective switch, 4) defective water solenoid valve (if you used to hear a clicking from the rear of the fridge when dispensing water - it could be a bad switch OR solenoid) or crushed / kinked water supply line (but if you have an auto ice maker that works - that's not the problem).
May 18, 2015 | GE GSL25JFPBS Side by Side Refrigerator
Should have posted the model number, based on your issue, it sounds like a intermittent water valve, should be replaced,a bad dispenser switch, or a faulty relay on the main board.
Apr 28, 2014 | GE Refrigerators
Water dispenser ice maker
If you check the backside of your refrigerator...
There are TWO (2) different electric water-valves...
A generic WHIRLPOOL part number = wr57x10032
(typically you can hear the "THUMP" when the are working...
WATCH this attached video...
Hope this is helpful...
Carnac the Magnificent
Dec 07, 2017 | General Electric GSH25JSXSS Stainless...
I have a GE GSS251 FREWW side by side with water, crushed and cubed ice in the door. The water dispenser quit dispensing water, the ice dispensers still work. I've replaced the filter. Is there an...
There is something similar to a motor that controls the flow of water, it's called an inlet solenoid valve. I will look up some information and post more details briefly.
Feb 05, 2011 | GE Refrigerators
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
See my earlier post of 6-4-09 for the solution to this problem. There is a GE part you can buy the solves the problem. It is part #WR49X10173 -- it's called a "Dispenser Water Tube Heater Kit". The part costs $32-35. GOOD LUCK!!
Apr 12, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Wont dispense water
Did you check the pump at the bottom of the fridge ,and also the solenoid. valve to release the water ,does it click when you depress glass against sensor in dispersal area
Dec 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water line is frozen in freezer door. I fixed mine by leaving the light on the dispenser on. It took about 6 hrs, but the little heat from the light bulb was enough to defrost the water line.
Nov 27, 2007 | GE GSH25JFPWW / GSH25JFPCC Side by Side...
Water in door stopped dispensing
We just had this happen on our Kenmore side-by-side and we had to replace the water valve and now it works great.
Aug 17, 2007 | GE GSS25SGMBS Side by Side Refrigerator
Mar 10, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
679 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
