Question about Bertini 906T TWIN - Navy Check Standard Stroller
WHEELS!!! HELP!! THE CLIPS THAT HOLD THE WHEELS ON TO THE PRAM KEEP LETTING THE WHEELS JUST FALL OFF - NO MATTER HOW HARD YOU TRY PUTTING THEM BACK ON AND EVEN ONCE CLICKED IN TO PLACE THEY STILL FALL OFF RANDOMLY AFTER 5-10MINS WALK. THIS STILL HAPPENS WHEN FULLY PUMPED! PLEASE CAN ANYONE GIVE ME AN IDEA AS TO WHAT I CAN DO, AS NOW I JUST DONT TRUST IT TO TAKE IT ANYWHERE.I AM PREGNANT WITH MY 4TH BABY AND WOULD LOVE TO USE THIS BEAUTIFUL PRAM AGAIN BUT IM TOO SCARED INCASE I HAVE TO DRAG IT HOME CARRYING ALL MY BABIES!!! ANY IDEAS WOULD BE REALLY HELPFUL KAREN
You have to replace the spring inside the wheel hub. the same thing was happening to me and my husband made a new spring out of spring steel. I guess they just loose their strength after a while. It was very frustrating!
Posted on Jul 23, 2010
SOURCE:
How do i stop the swivel wheels falling out
They are hold in place by elastic clips. They fall out because they are now loose from wear.
All you can do is to try to crimp them back in place.
Oct 20, 2014 | Miele S7000 S7260 Cat & Dog Upright Vacuum...
How do I attach the wheel caps to the elliptical frame?
Should be C-clips holding the wheels on that the caps just pop over to hold everything on.
Sep 09, 2014 | Fitness Quest Eclipse 1100 Hr/A Elliptical
Total jerkface happy wheels
sweet! Did you have a question about them? Cannot help you without any question. Keep up the great posting so I can get points for answering these types of posts.
Try holding down S key and see if it will boot into safe mode,
Try holding down option key and see if it will boot into drive select mode
try resetting the pram or nvram by holding down the apple and option keys on left of space bar and the letters p and r while computer is off and then keep them help down and power up machine. Hold them down until it chimes three times.
Good luck
Feb 07, 2014 | Computers & Internet
Where can I get replacement rear wheels for Mountain Buggy Urban pram?
check out
http://www.pushchairs.co.uk/acatalog/miscellaneous_spares.html
Dec 08, 2011 | Mountain Buggy Urban Single Stroller
The back wheels of my pram seem to slant inwards. starting to get really hard to push pram. please help!
This sounds like your axle washers are bent. I would suggest that you get replacement axles and starlocks. You can usually get these on eBay.
Hope this helps.
May 27, 2011 | Phil & Teds E3 Jogger
Im having trouble putting the pins in the rear of the pram wheels
It could help to put both wheels in, then keep on wheel/side in place with your chest, then pull the other one with both hands untill both wheels "click".
If this wasn't your problem please describe a bit more specific.
Kind regards
Apr 21, 2011 | Graco Baby Gear
Bought second hand oberon pram for my daughter for xmas which is in excellent condition[silver cross],but wheel keeps coming off. I dont think the wheel is the problem as i switched wheels and it still...
There should be a lock ring to hold on the wheels. These wear and fall off or become warped and will not hold on the wheel. What I did was drill a tiny 1/16" hole at the end of the axle. Put on the wheel and put a small cotter pin through the hole.
Good luck and thanks for your question and I hope my suggestions help. Don't forget to rate me.
burdfrenzy
Visit My eBay Store!
http://stores.ebay.com/Pittsburgh-Joes-Pants-Nat
Jan 07, 2011 | Toys
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
Silvercross pram
Try Ebay- I have been looking for pram wheels for my son's gokart and there are quite a few silver cross ones which come up from time to time. May be pricey- but cheaper than a new pram! Set up an Ebay search for it or try 'want it now'.
Oct 14, 2008 | Silver Cross Baby Gear
Emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
Aug 02, 2008 | Baby Gear
Bertini 906T TWIN - Navy Check Standard Stroller Logo
287 people viewed this question
Top Bertini Baby Gear Experts
Dorel UK
Dorel UK
Tom Chichester
Are you a Bertini Baby Gear Expert? Answer questions, earn points and help others
