Question about Whirlpool Refrigerators
How do you remove the base grille to clean it. The refrigerator is a side by side with ice maker. Moder WF-L400 I think.
  • yankeetee Nov 20, 2008
    This is not the dispenser area. It is the very bottom grill on the fridge. Do I still disassemble the ice dispenser?? Why would I have to dissemble the door to get the bottom grill off?
    Genius:
  • 1,550 Answers
The grill is pressed into clips that secure it in place. Just firmly pull the grill off the clips to remove. Be sure to not use anything metal to clean behind the grill.
Posted on Nov 16, 2008
    Scholar:
  • 126 Answers
Hello yankeetee,
On the bottom of the fridge is where the base grill is located, gently pull out one side and then the other. To put it back on, line it up on both side of the fridge and push it in gently, should pop back on.
Here is a link to the actual manual. http://www.estateappliances.com/data/2311958.pdf
Let me know how it works out for you.
ps be gentle when removing the base grille as they have plastic clips that snap off very easily.
  • 734 Answers
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help
  • 1 more comment
  • futureloginn
    futureloginn Nov 20, 2008
    try the link for more help==
    http://www.estateappliances.com/data/231...
  • futureloginn
    follow the link to remove base gril==
    http://www.fixya.com/support/p127172-ge_...
  • futureloginn
    follow another link=
    Sergeant:
  • 229 Answers
The bottom assembly has tabs on each side that disengage easily, then remove the base clean thoroughly and replace. Hope this helps. Good Luck
How do I remove the base grille from my Whirpool side by side refrigerator?
It is attached with friction latches and can be removed by tugging it
Mar 03, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
What is part number for water filter?
Hello there:
Water Filter
Item # 1017291
$35.75
Item # 1017291
img-descriptiontab-on.png Ice and water filter in front access grille for refrigerators made by Whirlpool, including some Kitchen Aid and Kenmore refrigerators. This is manufacturer part 4396508, and it replaces 4392857, WF-NL300, WF-L500 and 4396163. Replace every 6 to 12 months.
Related Items:
Jan 26, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have a ED2FHEXN Whirpool Refrigerator. Where is
Your fridge was made with 2 different types. it will be either one or the other.
the first one could be:WF-NL240 part number :#4396508 use replacement NL240
should run about $32.99
the second one could be:WF-L400 part number:#4396508 use replacement L400
this as well should run about $32.99
I would highly recommend that you contact whirlpool to find out which filter you will need since they used 2 different ones on your model.
You can reach them by phone or e-mail.
phone:1-800-253-1301
e-mail:www.whirlpool.com
I hope this helps you. IF you need further assistance please feel free to contact us at any time.
Jan 08, 2010 | Whirlpool ED2FHEXN Side by Side...
Removed ice maker drawer and replaced it, but now
The bar is down?! ;) There is no feeler arm on the "ice in the door" fridges... Check if the switch on the right from the icemaker is in "on" position. If it is:
  1. Remove ice bucket from the door, and re-seat it. If it sits high - you'll have no ice. If this did not help:
  2. remove grille on the bottom of your fridge, and find the testing procedures sheet for the icemaker tucked inside that grille.
Nov 02, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool gold moder GC5SHEXN503 side by side-ice maker not producing ice anymore--water dispenser works fine--laser lites seem ok---no ice jam--no water filling ice molds
Put some water in the ice maker and see if it will kick a batch out. If it does make a batch but does not make any more then replace the water valve. NOTE: the water valve is a dual purpose valve that supplys water in the door and supplys the ice maker. If the ice maker does not kick out a batch then something is wrong with the ice maker.One easy component to replace is the ice mold thermostat.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 20, 2009 | Whirlpool GD5SHAX Side by Side...
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Making lot of ice
I'm going to guess that there is something jammed into the ice maker making it misbehave. Power it down and have a look. Most units remove for cleaning.
Nov 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker LG side by side
What is the model #? Get it off the sticker inside the refrigerator side.
Oct 08, 2007 | LG LSC26905TT Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
