Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
Stereo channel
How do I use the 2 stereo channels. Can I run a mandolin and harmonica into 1 stereo channel via the jacks at the same time.( useing 1 stereo channel for 2 instuments)
  • g_mulholland Nov 16, 2008
    Thanks for your help. Its nice to get a strait forward answer. I`ll use separate inputs. I just don`t know what the stereo channels are for !!!
    Brigadier General:
  • 6,966 Answers
Hi again,
I was just checking other related questions when I saw your post. I am afraid that each would have to use separate inputs. Please check your original posting for added information.
Hope this be of additional help/idea. Pls post back how things turned upor should you need additional information. Good luck and kind regards.Thank you for using FixYa.
Posted on Nov 16, 2008
  • Louie  Role
    Louie Role Nov 16, 2008
    Appreciate the comment back.
    Since your concern were addressed, might I request that you rate this as you see it fit.
My AKG C1000S shows a weak signal from one side of the two stereo channels when I use an XLR going to a 1/4 inch Stereo jack. Does the mic only work properly with a Mono jack?
You have connected the mic improperly. You'll need an XLR to 1/4" transformer to properly match the impedance, then run into a mono channel.
Mar 15, 2012 | AKG C1000S Professional Microphone
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
May 20, 2011 | Yamaha YST-M7 Computer Speakers
Cant hook computer to mixer for you tube music
You would need a stereo splitter taking a 1/8 inch stereo plug for the computer into two 1/4 inch jacks to plug into two channels of the mixer OR a 1/8 to 1/4 TRS cable that you go into the Stereo (L) of one of the stereo channels... OR a 1/8 inch splitter to RCA plugs going into the TAPE input jacks of the mixer. You can't really go via the USB cable easily from YouTube,
Mar 30, 2011 | Behringer XENYX 2442FX Mixer
I need to know step by step how to hook up my entired system using my macki board. I have a Mackie 1604 Vlz, a power amp for mains, a power amp for subs, a crossover, a vocal effects processor, and a 16...
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Nov 25, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
I have the Eurolive B212A speaker,and the Xenyx 1202fx.I want to play my Ipod using this set up.Please help with connection
The Ipod is stereo and your speaker is not, so don't expect stereo.
Find a 1/8 inch stereo cable that splits the two channels into individual cables and enter those into two channels of the 1202 mixer. You might find a cable that goes from the 1/8 inch stereo and splits to two RCA type jacks which you have to either find RCA inpouts on your mixer or get two RCA to 1/4 inch adapters.
Crank the pan controls clear to the left on those two channels. Run a cable from the 1202 left main out to your speaker input.
Adjust the controls as needed.
Jan 03, 2010 | Behringer Music
Hello i have a medion 5.1 active sound system and i am trying to install it to an acer 5335 laptop but for some reason it will not work. i am using the usb method can you give me some advise and help...
hello Paul,
I understand that you wish to connect an laptop computer that has a standard stereo out(2 channels), earphoe jack or adio out to an active stereo system that supports the dolby 5.1 multichannel souround sound.
That is where the problem starts.The active sound system has more input channels than the two stereo channels given by the laptop, so connecting them via adaptor (audio out from laptop, earphone-like, 3.5 mm' male' jack to red and black chinch plug,'male' version to stereo L(left) and R(right) channel in at the active system) may provide you with extra stereo sound enhancement(like any other amplifier would), but no real surround sound..
To solve this, you would need a stationary desktop PC with an extra surround soundcard
that has all the multi channel out in it, as there is no chance to upgrade your laptop with such devices I am sorry to tell you that you perform an impossible task to get surround sound from your laptop.
Sep 11, 2009 | Audio Players & Recorders
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Need specs and wiring options
  • 105W x 4 Channel Max. Power Output at 2o.gif Stereo
  • 60W x 4 Channel 0.1% THD at 2o.gif Stereo @13.8V (RMS Continuous Power)
  • 40W x 4 Channel 0.1% THD at 4o.gif Stereo @13.8V (RMS Continuous Power)
  • ChannelFlex Crossover
  • Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
  • Low-Pass Frequency (120Hz)
  • Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
  • High-Current, High-Speed Output Devices
  • High-Efficiency, High-Energy MOS-FET Power Supply
  • Audiophile Grade Component Selection
  • Intelligent 7-Way Discrete Protection Circuitry
  • Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
  • High-Level Input - Add on Capability
  • Epoxy Composite PCB
  • 2o.gif Stable Design
Each 6 1/2" speaker will see 40 Watts
Each 6"x9" will see 521/2 Watts
Yes your solution is correct. Front wired in stereo, bridge rear.
Dec 29, 2008 | Eclipse Car Audio & Video
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
Open Questions:
Car Audio & Video Logo
48 people viewed this question
Top Peavey Car Audio & Video Experts
Marvin
Marvin
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
