Question about Lexmark Office Equipment & Supplies
  • Lexmark Master
  • 4,338 Answers
Here is the user's guide,see page 17 for instructions:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 16, 2008
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
I can't figure out how to replace the ink cartridge. How do you remove the old ink cartridge and put in a new one?
Here's an article in the Lexmark website that will guide you on how to replace the ink cartridges on your Lexmark X5150 printer. Just click on this link: Follow the instructions carefully. By the way, in some cases, the ink cartridge carrier doesn't move in the loading position even when the printer is on when you lift the scanner unit open. If that happens, unplug the printer from the power source. With the scanner unit open, hold the solid white tape you see in the printer. Slowly slide the cartridge carrier to the center for easy access. Replace the cartridges. Close the cover, close the scanner unit. Plug the printer back to the power source. Hope this helps. If you need more assistance, just place a comment so I can get back to it.
Apr 19, 2010 | Lexmark X5150 All-In-One InkJet Printer
Printer says unlock. did this and still says it
Try resetting the printer and shaking loose the scanner. Remove the ink cartridges, move the red lock from the down position to the up position and then back down. Unplug the printer and turn it onto its left side. Return it to the upright position and plug it back in.
Repeat the lock movement and shake again then plug it back in and reinstall the ink cartridges. Try to print and scan again.
Check your firmware is the most recent version. has the links for Windows and Macs
Apr 16, 2010 | Lexmark X83 All-In-One InkJet Printer
How to clean the Lexmark X83
Things You'll Need:
* Cleaning Solution For Plastic
* Cleaning Cloths
* Cleaning Cloths
Cleaning the Outer Case
1. Step 1
Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
2. Step 2
Check the printer manual. If the manufacturer has provided specific instructions, follow them.
3. Step 3
Turn off the printer.
4. Step 4
Dampen the cloth with water or cleaning fluid.
5. Step 5
Wipe the outside of the printer, making sure that no fluid gets inside.
Cleaning Cartridges or Ink Nozzles
6. Step 1
Use the cleaning buttons on your printer if it has them.
7. Step 2
Initiate cleaning through the printer software.
8. Step 3
Open the printer software by double-clicking on a printer icon or opening a document and then selecting Print from the File menu.
9. Step 4
Click a button labeled Options, Troubleshooting, Clean Print Cartridges, Toolbox, Printer Utilities or something similar. (This varies by manufacturer.)
10. Step 5
Click a button labeled Head Cleaning, Run Nozzle Check, Clean Print Cartridges or something similar to begin the process.
11. Step 6
Follow the instructions on your screen.
12. Step 7
Repeat the cleaning process if the results aren't satisfactory.
13. Step 8
Jan 27, 2010 | Lexmark X83 All-In-One InkJet Printer
I have an Epson CX8400 printer and I just installed new ink cartridges (genuine Epson)all four and I get the error message "cannot recognize ink cartridges".
Try the following:
1. double check the part numbers of the cartridges and also their expiration date.
2. reseat the cartridges
3. after you place the cartridges back, close the scanner part and press and release the stop button.
4. If same issue, either an issue with the cartridge(s) involved or the printer itself
Hope this help
Feb 25, 2009 | Epson CX8400 All-In-One InkJet Printer
Faded/bad coloring on color printer/scanner - Kodak ESP5
Take out both the colour and black ink cartridge and look on there sides as there would be a number written on the side.......this is to determine if the ink cartridges are genuine or are few numbers for the ink cartridges if they match and still have issue then its a print head issue else bad ink cartridges probably refilled........
  • 1K3156
  • 1K3157
  • 1K3178
  • 1K3177
  • 1K3189
  • 1K3190
  • 1K3627
  • 1K3622
  • 1K3629
  • 1K3638
  • 1K3620
  • 1K3621
let me know how many have ink cartridges that do not match these numbers.........let me know if this was helpful.........
Dec 15, 2008 | Kodak ESP 5 Printer
Ink cartridge problem
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Mar 18, 2008 | Lexmark X6150 All-In-One InkJet Printer
Lexmark X83 Printer Copier Scanner
when u refill the ink in cardge so its cant detact thats y the earror is coming due to its compny ink its happen in all prineters
Feb 26, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X83
open the door on the printer. YOu'll see both cartridges. Pull them towards you until they click, then pull them out. Replace with new:)
Jan 10, 2007 | Lexmark X83 All-In-One InkJet Printer
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
