Brown sludge under drum making washing dirty
I did a 60 cotton wash yesterday and all the towels came out covered in brown marks and a brown sludge was left behind in the drum. It came from the outside of the drum under the rubber seal probably because I used the hotter temperature than my normal 40 easy care. How can I get rid of this sludge and prevent the problem please?
I always use calgon in every wash but this is a hard water area.
    Champion:
  • 211 Answers
You can try to wash on a high temperature with some soda instead of washingpowder.
And offcourse without any clothing in it.
Due the modern washingmethode's the temperature is always very low.
Then you get some dirt sticked into your machine.
We had the same problem, but it's solved now.
Hope it helps,
Gerard
Posted on Nov 17, 2008
Fisher and paykel does Epsom salts work in the rinse water
Hi! Have you completed a "Clean Up" cycle? It should prompt you every 100 washes to do a clean up - it should be under the "Lifestyle" menu. When you do it, I suggest you use OXY soaker (1 whole Cup) instead of normal detergent and make sure it is all HOT water. It soaks for 4 hours, but is very good at cleaning the bowl and workings to stop brown marks on your clothes and towels
Oct 10, 2014 | Fisher and Paykel Aquasmart wl80t65c
Bosch Maxx 2000 leaves brown sludge on washing. Has it died?
Is the rubber seal around the drum perished or has it not been cleaned for while? The seal should be wiped out after every use, you may find it full of gunk if you run a cloth around inside the seal.
May 05, 2012 | Washing Machines
Brown marks on clothes. I have put the machine on a boil wash with nothing in it. washed all pars of machine and it is still happing, Please help
Does the drum sound noisy when it spins if it does then I would suspect the bearings are badly worn and the grease from the bearing is getting inside the drum.
Hope this helps.
May 16, 2010 | Zanussi FJD1266W Front Load Washer
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Oct 15, 2007 | Washing Machines
Brown staining of clothes,increased noise on spin cycle
that brown sludge is grease from the bearings and the noise is the bearings breaking up stop using the machine and get them replaced 2 supply and fit new bearings and drum support should nt cost more than £90 good luck not realy a job 4 a novice
Aug 06, 2007 | Hotpoint Aquarius WF000 Front Load Washer
White wash contaminated with brown marks
drum bearings are leaking oil into the drum..they need replacing.
Mar 11, 2007 | Hotpoint Aquarius WMA52 Front Load Washer
Washing Machines Logo
877 people viewed this question
Top Washing Machines Experts
