Question about Onkyo DR-C500 Multi-disc DVD Player
Dvd stops dvd will play half way then start freezing the frame, have to fast forward a bit to get it to correct. thanks, katman
  • 50 Answers
Hi "DVD players with freezing video", is a common problem, and is usually a sign of a bad laser, or video processor, that give out after they heat up part way through a movie, but what you describe about fast-forwarding a bit, and the problem goes away, would lead me to believe that the problem is not either of those. It sounds like there may be possibly some obstruction on the sled rails that the laser rides on, or sometimes the nylon gear that moves the laser splits, or has dirt in the teeth that can cause this problem. It sticks at a certain spot, then once you get past that spot it operates fine. If it was a single disk player, I would say it would be worth taking the cover off to see what you could see, (being careful not to expose your eyes to laser radiation,)but being a multi player, it is very difficult even for a tech to watch the mech operate. I hate to say this, but I would advise you shop around for a repair place that has a low bench fee to check it out, and if it's dirt in the teeth, it should not be an expensive repair. I don't know what you paid for it, but Onkyo has been a high end brand, and it's a multi player, so it may well be worth it. I hope this helps you in some way!
Posted on Nov 30, 2006
My panasonic dmr-ez48v freezes intermittantly when playing dvd's.
perhaps broken gear that moves the laser CARRIAGE contact avsystemparts.com
Feb 25, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
Dvd freezing
is ur dvd player in an inclosed area because they need air and some more than others. is the device getting hot to the tuch. if it is then put somthing under the corners of the dvd player to raise it up. this should stop it from over heating. also try cleaning it. please rate my suggestion. thanks
Feb 01, 2009 | Sony DAV-DX150 System
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Jan 21, 2009 | Televison & Video
Video playing in fast forward with no sound
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Jan 05, 2009 | Canon PowerShot G9 Digital Camera
Jsi js4110
The only operations available on the JSI JS4110 without a remote are play, pause, stop, and eject. Since this DVD player "remembers" position of the movie, a different DVD would have to be inserted and played to start that movie over from the beginning. As for fast-forward, this is only available with the remote.
May 13, 2008 | Philips PM3S Remote Control
DVD Freezes
THE Laser lens of the built in dvd needs cleaning buy a dvd lens cleaner at walmart ,target,or walgreens then try tv after cleaning buit in dvd player laser lens
Dec 25, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Onkyo DR-C500 Multi-disc DVD Player Logo
Top Onkyo Televison & Video Experts
Steve
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
