Question about Panasonic DMR-E85H DVD Recorder
DMR-EZ25EB U99 error code
DVD recorder will not work. U99 on display when swtiched on.
  • hteinc Dec 18, 2008
    i also have the same u99 failure code .help
5 Suggested Answers
  • 13 Answers
SOURCE: my panasonic dvd player and
Yes, U99 is a software issue most of the times, you can check this website for the newests software version for your player:
http://www2.panasonic.com/consumer-electronics/support/Drivers-and-Downloads/list-DVD+Recorders
Try updating the firmware (software) on your player, if not you might need to send it for service to a Panasonic authorized service center.
Posted on Jun 23, 2008
SOURCE: Panasonic DMR-E30 with U99 fault
Saludos : Yo tenia el mismo problema. Mi dvd DMR-E30 tenia el
mismo problema . Codigo U99 . Y no funsionaba nada.
Entre a la pagina de soportes de Panasonic y baje el Firmware.
Luego lo grabe en un cd ,el cd lo coloque en la dvd y la dvd se actualiso automaticamente. La dvd funciona perfectamente tanto
con DVD-RAM como con DVD-R. Esta solucion la saque de esta
misma pagina fixya . Gracias Fixya. Att. LACF
Posted on Jan 01, 2009
SOURCE: Panasonic Video/dvd player DMR ES30v Fault code U99
Hi,press the power button on the dvd so it goes to standby,then press the power button again to turn the unit on.I hope this helps.Jamie
Posted on Mar 13, 2009
BLAZZ81
  • 281 Answers
SOURCE: I am getting a U99 error code. The only function
The "U99" error code signifies a "general communications failure."
It is not associated with one specific problem.
It can be related to the version of firmware your DVD recorder is currently using and it has been associated with the TV Guide on screen guide.
If your unit displays U99, turn the power off-unplug the
unit for 5 minutes, and reconnect the power.
If U99 reoccurs, please contact the Global Service Center Network for assistance.
Posted on Feb 26, 2010
DVD Recorder MODEL no.DMR-EZ27EB has U99 on screen unable to operate it
Hi.
U99 is a general communication failure between processor and timer, and there may be different causes. Common cause is a defective disk. Removing disk from the drive sometimes may fix the problem.
The first reset that you can attempt is disconnecting power for two minutes.
I quote below a post that was originally published in the MyCe forum (here):
"According to the service manual the U99 error is specifically a "hang up" displayed when there is a communication error that has occured between the main microprocessor and the timer microprocessor.
With more than twenty Panasonics (including four DMR-ES15 models) I'll offer my own observations:
There can be any number of causes for the U99 error, including a culmination of reading, writing, finalizing errors--sometimes appearing after U61 or U88 reading errors. The U99 error might also be associated with unusual DVD Drive noises, "grinding" indicating a dirty rubber hub and spindle; "clunking," "chugging" or "errrp" noises indicating a dirty lens or a failed laser assembly (the "optical pick-up").
Initial remedial measures include the routine DVD Drive lens, rubber hub and spindle area cleaning described in other CDFreaks/MyCE and AVS Forum threads. If that does not correct the problem(s) laser assembly or DVD Drive swapping with a direct replacement may be indicated. Also check for a disturbance to a ribbon cable or ribbon cable contact, correct or repair as necessary.
If the Digital PCB has become problematic, model-specific replacement is indicated. If the DVD Drive on-board contoller (if so equipped) has become problematic, model-specific replacement is indicated. In most cases "model-specific" means the same model year DVD Drive and, with problematic Digital PCBs or DVD Drive controller boards, replacements should be from the same model year and the same or very similar model recorder. Laser assemblies should only be replaced with the same model, i.e., 3331A and 3332A "optical pick-ups" might not interchange satisfactorily.
The U99 error may also be displayed when inferior media is in use. (Beginning in 2008 I've used nothing but Taiyo Yuden 8x Premium Line DVD-R media in my Panasonic, Philips and Magnavox DVD Recorders and HDD/DVD Recorders.)
The U99 error may also be displayed when there is an operating system "time out" occasioned when the user attempts to move too quickly between digital and analog channels (in 2007 and newer EZ series models)."
Apr 26, 2011 | Music
Display reads slf check and u99 whichIthink is a fault code.The unit is apanasonic DMR-ES30VEB dvd recorder/vhs.Any ideas?
Hi
U99 is a fault code, from memory i believe it is a communication error between the dvd drive and its controller, either way the machine needs to be serviced.
regards
TechSupp12
Dec 12, 2010 | Panasonic DMRES30V DVD Recorder/VCR Combo
Feb 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Mar 12, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
U99
A U99 error code signifies a general communications failure and is not associated with any specific problem. It could even be related to the firmware version of your DVD recorder.
Try turning off the power and unplugging off-unplug for at least five minutes before reconnecting.
If U99 reoccurs, you should contact the Global Service Center Network for assistance.
Jan 27, 2009 | Panasonic DMR-ES10 DVD Recorder
Jun 29, 2008 | Panasonic DMR-E30 DVD Recorder
Dvd would not work displays u99
Dvd recorder doesn't not work. Displays error code U99. Any suggestion please?
Jun 21, 2008 | Panasonic DMR-E85H DVD Recorder
Start up u99 message
Hi there, this is what Panasonic say.... The "U99" error code signifies a "general communications failure."
Feb 17, 2008 | Panasonic DMR-E20 DVD Recorder
U99
Feb 12, 2008 | Panasonic DMR-ES10 DVD Recorder
Recording
mine too. i found a firmware update that seems to have helped (i tried recording about 10x after this update and it's ok so far).
Oct 24, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
