Question about BenQ FP731 17" LCD Monitor
BenQ, power is on, screen is almost black, just very dark
Hello
I have a benq, I've read other posts, but I thought with the info of it being very dark, almost black, but can still see a bit, someoen could help me pin point the problem.
Thank you.
  • 2 more comments
  • bazaaa Nov 19, 2008
    They said it would cost about $120-$150 to fix.
    I read this in aonther post:
    "Its a problem with the inverter. check the 4 transistors, C5707 near
    the connectors for the backlight. If none are defective, look for the
    PF751 FUSE. It sure to be busted.You can replace that with another 3A
    fuse. Remember, you should only replace the fuse if you are certain
    there are no busted transistors in the inverter board. Otherwise, you
    now have a refurbished Benq Monitor"
    How do I check the transistor, if it's good or bad?
    And how do I know if the fuse is busted? Broken? It looks okay to me.
    Okay, thank you very much. That is too difficult for me. I phoned one of very few LCD places here in the city, and they said it would cost about $120-$150 to fix. So it's not even worth it I guess.
  • Anonymous Nov 24, 2008
    Benq, power is on, screen is almost black, just very dark problem. Just looking at a Benq FP731 which my boss had replaced the capacitors on but that did not fix it. He decided to scrap it! I just checked it and found that it read 1Mohm across the fuse for the inverter. Checked the transistors but none found faulty. Replaced the fuse and its working fine. It's now been on for an hour without any problems.
  • DKRASH Jan 27, 2009
    Where can you buy this 3A fuse that that needed to be replaced? Its PF751.
    Also, what is the best way to test the fuse if you are using a digital muiltimeter? Thanks.
  • 153 Answers
You can not fix this problem from the panel buttons, the problem is something to do with the circuit board. Its the inverter cicuit that has one or couple of components faulty. I susgest you bring it o the repair shop. cheers.
Posted on Nov 19, 2008
  • Trevor Sauna
    Trevor Sauna Nov 19, 2008
    Its complicated if you don't know how to use a multimeter to check and
    understand how transistors are checked using the resistance test. For
    the fuse just use a analog multimeter put knob to X10 and connect the
    two probes to the terminals of the fuse and see if the needle
    points to zero that means fuse is OK if not the fuse is open. for the
    transistors we go step by step.
    Step by step instructions:
    The instructions are given primarily for transistors as these are the most common types in use. The variations
    are shown for PNP (positive, negative,positive)varieties - these are indicated in brackets (.. ..
    1. Set the meter to its ohms range - any range should do, but the middle ohms range if several are available is probably best.
    2. Connect the base terminal of the transistor to the terminal marked positive (usually coloured red) on the multimeter
    3. Connect
      the terminal marked negative or common (usually coloured black) to the
      collector and measure the resistance. It should read open circuit
      (there should be a deflection for a PNP transistor).
    4. With
      the terminal marked positive still connected to the base, repeat the
      measurement with the positive terminal connected to the emitter. The
      reading should again read open circuit (the multimeter should deflect
    5. Now reverse the connection to
      the base of the transistor, this time connecting the negative or common
      (black) terminal of the analogue test meter to the base of the
      transistor.
    6. Connect the terminal marked positive, first
      to the collector and measure the resistance. Then take it to the
      emitter. In both cases the meter should deflect (indicate open circuit
    7. It is next necessary to connect
      the meter negative or common to the collector and meter positive to the
      emitter. Check that the meter reads open circuit. (The meter should
      read open circuit for both NPN and PNP types.
    8. Now
      reverse the connections so that the meter negative or common is
      connected to the emitter and meter positive to the collector. Check
      again that the meter reads open circuit.
    9. If the transistor passes all the tests then it is basically functional and all the junctions are intact.
    If this steps seems difficult to under stand, i would recommand you to
    bring the components to a technician to check it for you. Good luck.
How to fix my Benq Monitor which is scrolling full screens of different colours.
all modern LCDs have ONE and ONE only native screen size. since you did not tell us the model number we have to tell you maybe you are setting the wrong size. if the monitor has worked before then you are sending it the wrong signal.
Jul 25, 2016 | BenQ FP91V (Silver, Black) 19 inch LCD...
Can not see picture very dark
You may want to read this:
http://www.badcaps.net/forum/showthread.php?t=6053
And also look at failed Dell monitors (made by BenQ)
http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Apr 24, 2010 | BenQ T905 19" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Benq computer monitor shuts down after standby in energy saving..
There are 6 (reduced quality) capacitors in the BenQ Q9W5 which cause the screen over time to 'fail to sync' when turning on or resuming from standby.
They are;
4x 470uF 35v, and
2x 1000uF 16v.
I recommend the following replacements if you are in Australia (the ones I purchased from Jaycar only lasted 12 months);
(470uF) http://www.altronics.com.au/index.asp?area=item&id=R4865
(1000uF) http://www.altronics.com.au/index.asp?area=item&id=R5182
Mar 24, 2009 | BenQ Computers & Internet
BenQ fp737 monitor
Disconnect the signal cable from CPU and power on.You should get a BenQ Blue screen.
If no Display,Problem is definitely monitor related ie monitor has a hardware defect most probably the power/invertor board has a few blown components.
If you are technically able,you can dismantle monitor and check components on the Invertor board which you may find on my other posts.
Please reply if you need more help.Please rate this solution.
Thanks.
Samir
Aug 25, 2008 | BenQ FP737S-D 17" LCD Monitor
Dark disp-lay
sorry mate,that is dreaded power interter board inside lcd,read about similar benq model dramas here http://www.electronicrepairguide.com/benq-t705-lcd-monitor-repair.html
Jun 03, 2008 | BenQ T705 17" LCD Monitor
Monitor Randomly Turns Black
I have exactly the same problem with my Benq FP71E+ ..
What i found is a temp fix is this :
When monitor dims and goes black i turn it off , hit the bottom left side (near the BENQ logo) turn it on again and it works ..
This works every time for me . But after a while it switches off again , could be 5 minutes could be 5 hours . Its random
May 02, 2008 | BenQ FP71E 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
388 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
