Question about Lands Phones
How to cofigure epbx 303 incoming hunding ringing
I configure the system, All incoming call come reseptionest (101 jack). Now Jack 101 phone co line indication ( 1 to 3 ) blinking.Other jack phone intecation not blinking at same time please give me the solution
This is Tahir ansari from indore, I have faced problem of epbx machine, problem is that, I have 15 extention in my epbx & 3 telephone line connected in my epbx, now all 15 extention are used by me but 3 telephone line are not running my extention why ?
Posted on Jan 17, 2009
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
Sep 25, 2014 | NorStar T7316E Telephone
I can make calls but phone doe not ring
You said "it seems to ring once then stops." One possible cause of what you're describing is called a "Ring Trip." It is characterized when the button that flashes to indicate an incoming call changes to steady red (which would normally indicate the call is answered) although no one actually answered the call. If that occurs, then you have to test to see whether you can tell where the problem is coming from. If you unplug all the phones, you can then call in (from a cell phone or other phone that's not part of the system) and see if the incoming call rings unanswered, as it should when no phones are attached. If all rings in OK, plug just one phone in at a time and call in to see if any particular phone causes the problem. If one causes the ring trip, then disconnect that broken phone. If ringing still stops when no phones are attached, you'll have to disconnect the phones' connection wires (Station Wires) at the phone system box that plug into the "Station Ports" (label them before you unplug any!). Do not unplug the plugs for the wires that feed phone company lines into the phone system, the jacks are called CO line ports. With the "Station" wires unplugged, see if If all rings in OK by calling in from a cell phone or other phone that's not part of the system. If all rings in OK, plug just one station wire in at a time to see if one causes the problem. If one station wire causes the ring trip, then disconnect that troublesome wire and inspect its "system box jack" and its phone jack for water damage, carpet cleaning solvent, exterminator spray or any other corrosive liquid damage. Sometimes a staple through a wire where there's humidity can cause the problem. This process will find the offending wire, jack or phone that causes a "Ring Trip." There are many other possibilities, but the extremely limited description you've provided "it seems to ring once then stops." doesn't help me send you a better answer yet.
Jun 27, 2014 | Panasonic KX-T7730 Corded Phone
No access to outside lines from one jack
Hi, What you can try is check the plug connection. If they are bent or broken. Replace the cable to and from the phone. If that is OK then you know the phone is the problem. Take it to be repaired.
Jan 20, 2014 | Panasonic KX-T7730 Corded Phone
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA824 Phone Line Problem....When I connect the phone companies incoming line to my phone system everything works fine...When then attach my home phone to the incoming phone line with the...
If I'm understanding right, you are plugging in a regular "residential" phone into a phone system jack. The system phones work differently than home phones and you won't get a dial tone out of the jack unless you use a system phone.
Nov 04, 2013 | Computers & Internet
I cannot receive incoming fax, what setting do I have to use
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X4200 User's Guide.
  • Make sure the fax machine is connected to right phone jack in the wall and is assigned with the correct fax number.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 13, 2011 | Lexmark X4270 All-In-One InkJet Printer
I puchased one kx t 7565 x ph for my panasonic epbx it is not working what can i do i verified the epbx box one line the voltage is low
Let me see. A 7565 is an analog system phone, it requires 2 pairs to operate, and you'll see 24 volts on the inner pair and about 13 volts on the outer or data pair. You can plug the phone directly into the KSU jack, making sure you have a 4-pin base cord. Outside of that, I have no idea what "low voltage" is.
Carl
Mar 31, 2011 | Panasonic KX-T7565 Corded Telephone
When I plug the printer into the phone jack the house phone goes dead. The phone line is an ATT Ring Master, Distinctive ring is on on the printer
Are you sure you're plugging into the phone jack on the printer? The network cable jack will hold a phone jack.
The network cable jack is (from the front of the machine) on the left side, right above the USB port. The phone lines are in back, top center. The incoming line should go into the jack labeled 'Line', which I think is the one on the right when you're looking at them.
Jan 30, 2010 | Brother MFC-9840CDW Laser Printer
1 lines is ringing & another is not ringing
Somewhere you should have a programming and operating manual for your phone system. Typically in a Panasonic you turn on CALL WAITING for both Intercom and Outside lines via a code you dial at each phone on the intercom (7311# 7321# for a TA).
This is assuming that the lines are already programmed to ring at the phone.
Carl
Aug 21, 2009 | Panasonic KX-T7730 Corded Phone
Line 4 doesn't ring in coming call
The way 4 line phones work is that you need 4 lines on every jack that is connected to your phone.
You see the light probably because one of the phones has line conected and you see line appearance.
Mar 20, 2009 | Nortel Lands Phones
Lands Phones Logo
142 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
