Question about Oster 5711 10-Cup Rice Cooker
Oster 5711 does not make steam.
I have an Oster 5711. It powers on, the timer is set, it gets activated, but the unit does not produce steam.
Any advice on how to fix it?
Thanks.
3 Suggested Answers
SOURCE: lost manuel
I downloaded a manuel from the internet...thanks
Posted on Jun 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: need cooking instructions for Oster 5711 rice
Hello there;
You can follow this link and it will take you to where you can download the manual ok Hope that this is very helpfull
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Posted on Oct 14, 2009
  • 1739 Answers
SOURCE: I purchased the store display
You can download your User Manual for the Oster 5709 / 5711 / 5613 Food Steamer here:
http://www.oster.com/manuals/MANUALS/005711-000-000_43_96796875.PDF
Thank you for using FixYa!
Posted on Sep 16, 2011
Hi does anyone know anything about the frutina slush machine. Ive just bought a preowned one. Im not sure its working right and it didnt come with instructions. Thankyou
Well I live in Southampton, and Ice Frutina are based here. The liquids come in great big containers that you just pour in ready mixed I think (or perhaps its from concentrate, I'm not sure) but either way the mixing instructions should be on most slushie mix containers. For the machine to make slushie you basically need two things to happen...
1) the powerful refrigerator within the unit should function and chill/freeze the liquid in the hopper
2) The agitator should be constantly turning inside the hopper to break up the ice crystals as they form turning the liquid into slush rather than just a block of solid ice.
If the refrigeration is working, you should notice a pretty quick drop in temperature of the liquid in the hopper... It may be worth checking any fans are working properly and not seized up. Check the refrigerant compressor is humming.
That's about as much as I can help you I'm afraid. Hope it ends up working for you :)
Jan 07, 2017 | The Kitchen Appliances - Others
Ordered a cooks essential air fryer and didn't receive the separater
Contact the vendor who sold the unit to you. They should send you the missing part or a replacement unit.
How do i change nozzel on oil burner
Turn power off and isolate the fuel line/lines. Disconnect flare fitting on fuel line to the burner assembly. Open burner assembly...either the primary controller or ignition transformer should hinge open with a few screws on the other side. Should be a locking nut on the fuel line to the burner and electrodes...loosen and pull burner/nozzle/electrodes. I Don't recommend removing the electrodes if you don't know how to space them correctly, so unless you have a nozzle removal socket/ratchet, then use a deep well socket & back it up with a large pair of channel locks. Thread pattern is normal...LLRT. When replacing nozzle, Make sure you have the same gallon rated, spray pattern (hollow, semi, solid etc) , & degree (angle).
Jan 19, 2015 | Kitchen Appliances - Others
I need a replacement cord for chefs mark 12 in 1 toaster oven combo tb1080
I could not locate the exact replacement power cord for your toaster oven. If the power cord is a plug -in type, you can look on line, do a search " small appliance power cords", but I'm not sure if you will be able to match up the correct cord. I think your best bet is to go to a local. old fashioned. hardware store or to a small appliance repair center. Take the original power cord with you to match it up.
May 29, 2014 | Kitchen Appliances - Others
Need to replace the heat stripe tape on my tilla foodsaver vaccum sealer
concerning my food sealer: the strip under the heating wire came loose & would not stay in place. i almost threw the unit away but its at least $40 to buy another. i decided to buy a roll of PTFE Coated Fiberglass Fabric With Silicone Adhesive Tape. PTFE is Teflon but u cant use Teflon as a search term because of the copyright. i found a roll on ebay for $3 (free ship) from China (how do they do that!). it took about 2 weeks for the roll to arrive. I cut a strip to fit under the wire. The wire had burned & partially buried itself in the unprotected plastic. Be gentle when nudging it out & clean off any material that has attached itself to the wire. Seals & works like new!
would you like to buy the rest of the roll? the roll has about 28 feet left.
Dec 27, 2012 | Kitchen Appliances - Others
Tell me list of recovery software that you peoples experienced that working fine.i need software to recover data after formatting the hard disk.
Hey, you can use Card Data Recovery. It can help you recover data from formatted hard disk.
Itfeatures an extremely easy interface and powerful functions that allows usersto recover deleted and lost photos, music and video files. The software workswith Microsoft Windows® 2000/XP/2003/Vista and Windows 7, and it's very easy touse.
Dec 20, 2010 | Keating Instant Recovery 20AA (NG) Deep...
Oster 5711 10-Cup Rice Cooker Logo
Top Oster Kitchen Appliances - Others Experts
Irene Tulloch
mike cooper
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
