Question about SanDisk Sansa e250 MP3 Player
Sandisk won't turn on
Went through the wasner and dryer. Screen remains dark unless it is pluged in then it shows that it is charging but will do nothing else. Please help. Thanks, Jan
  • 1 more comment
  • Anonymous Nov 18, 2008
    samsung mp3 player went through the washer and dryer. it wont turn on even when plugged into the computer. How do i fix it?
  • slacker3 Nov 20, 2008
    it didn't go throught the wash but it only lights up when you plug it in. Nothing else happens
  • ljjohnson97 Nov 22, 2008
    Dried it for 6 days. Still the same. No change. Any other suggestions?
The thing turns on but only displays the battery being partial red.
Posted on Nov 20, 2008
    Sergeant:
  • 229 Answers
It needs to be completely dried on the inside. Carefully remove the outer cover and then leave in a fairly warm dry place for a couple of days or use a blow dryer on low(no heat setting) this needs to be done right away before the water corrodes the components in the device.
Hope this helps. Good Luck!
Posted on Nov 16, 2008
When i try to open my psp,my screen do not show any respon..i just can see it when i get to closd to psp screen..its to dark..plz help me sir..tq.
I would say the back light went out if you can see the screen but very dark. Unless you haven't tried adjusting any video settings it may have.
Apr 02, 2013 | Video Game Consoles & Games
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
My phone is not charging i pluged it in the green light flashes and than it goes dark i sent in to raipers thay had the phone for three and a half months and sent it back with nothing helpful done so...
hi
there must be fault in battery.just replace the new battery for your mobile.there some battery which charging capacity is low. try it after changing the battery.
thank you
Dec 17, 2010 | Sony Ericsson XPERIA X10 Cell Phone
I have a similar problem.
Actually it sounds like the phone is merely off. Perhaps the battery actually died. If so and then the phone is off. When you plug in the phone with while it is off it will show the logo then it will say please wait and the the battery icon and say charging. If the phone is charged it goes dark.
Just hold down the "end call" key for a minute and see.
This actually happened to me once. I thought my phone was broken. Just as I was about to call AT&T I decided to try turning it off which is done the same way as you turn it on. Imagine my surprise when it started right up!!!
Aug 10, 2009 | LG Vu CU920 Cellular Phone
Vaio laptop- screen went dark but is still on.
check power from adapter, if its ok, try looking at your function key and adjust brightness through function key. or else you might have to replace the lcd bulb....
Feb 18, 2009 | Sony VAIO PCV-W20 PC Desktop
Screen gone dark
It is natural to ipod the screen will be dark if has no power unless the LCD of your iPod is defected even it has a power its remain dark that’s the symptom of defected LCD screen. I hope your problem is a power failure only. Make sue your iPod is fully charged and then toggle the hold switch on and off. Then reset your iPod nano; Toggle the Hold switch on and off,(Slide it to Hold then it off again). Then press and Hold the Menu and Center (select0 buttons simultaneously until the apple logo appears ,about 6 to 10 seconds .You may need to repeat this step . If you having difficulty resetting your iPod set it on a flat surface .Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel,and not near the center. Then If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try your iPod nano with a different USB port on your computer, not a USB port on your keyboard or hub. iPod will stop charging if the computer, or portable computer, it's connected to enters standby, hibernation, or sleep mode. To charge your iPod, connect it directly to a computer's USB port and make sure standby, hibernation, or sleep mode is turned off. If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly. If you have an Apple iPod USB power adapter you'll be able to charge your iPod without leaving your computer powered on. If all procedure above for power to on is not working then its better to replaced the battery with anew one so its works normal again.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Apple iPod nano
Sansa crashed have white screen
I have a e250 also and it white screened. I could'nt shut it off. I just left it on overnight and 1/2 of the next day until the battery went dead. Then pluged it in. It Worked!!!!
Jan 19, 2009 | SanDisk Sansa e250 MP3 Player
Nano Ipod- screen is dark
sorry to say unless your prepaird to get it fixed then you won,t solve the problem as the screen as died and needs replacing or for what price they are i would advise you bye a new one ?
Dec 03, 2008 | Apple iPod nano 3rd Generation
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
