Question about HP Color LaserJet 2600n Printer
No black printing out in my 2600n printer
My husband bought this printer 2 years ago. but we're not using it that much not until I went back to school. I've printed a lot of homework now and I noticed that the black ink is still full and all other colors are half empty. I tried to print it in greyscale but still no black ink. Please help me!!!!
    President:
  • 2,992 Answers
Try taking the black toner cartridge out, hold it by its ends and rock it back and forth several times. Also gently tap on the catridge a few times too. This will dislodge and redistribute the toner which is still inside.
Posted on Nov 16, 2008
I am using the HP Laser Jet 2600n and I only use the black ink, I have it set up that way, for financial reasons. Why is it not letting me print? It is saying that my magenta is out, and will NOT let...
First of all, for financial reasons you don't use a color printer. Unless you print graphs.
Second of all, this is a laser printer, it doesn't use ink.
Third, all four toner cartridges must be inserted and working in order to print in any color.
Go back and read the "First of all" again and buy a B and W laser printer.
Dec 07, 2010 | HP Color LaserJet 2600n Printer
I have a hp color laserjet printer 2600n. the black ink is new but on e of the other colors is out. I can't even print in black. Can I override the message on the printer?
Yes you can. Press the arrows until you get in the screen the option system setup and press the check, then press the arrows again until you get print quality and press check, go to replace supplies and press check, press the arrows and you will see the option override out, press check two times and the unit will get back to ready, It might do a calibration but after that the unit will ignore the toner level and will print. By the way you can use color if there is still toner inside the color cartridges
Sep 05, 2010 | HP Color LaserJet 2600n Printer
Hp laserjet 2600n printer creates 1/2" wide band that you can almost see the print...like it is not getting toner in black color.
This often happens when cartrage has run past changing point. remove cartrages starting at top and CK for ink. Run cleaning page until clear
Jul 04, 2010 | HP Color LaserJet 2600n Printer
Won't print black
chack your balck cartridges may be it's finish just tak out seak that will fome to know is the ink of finish
relpace that it will work fine
May 10, 2010 | Brother MFC 490cw Color Inkjet...
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
My hp 2600n color laserjet leaves RED DOTS on the printed document. What should I Do?
look at the red cartridge do you see any dots on it ? is it only when you print? what about if it's just Blk & wht?
Jul 21, 2008 | Sharp AR-5320 Black and White Copier
HP Color Laser Jet 1600 Problem
Hey I have 1 problem I have the printer of 2600n when i give print Command of RED Colour its come orange and right side i get light print and left side i get little dark print , what is the problem i don't understand any can help me . Thank u Morgan.M
Dec 12, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
