Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and Stainless Steel
Problem for Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and...
My coffee grinder on my
By jaimaraim on Nov 16, 2008
My coffee grinder on my new machine is not working
Same Problem
Nov 27, 2008
-   blade wobbles
-   seanfreda4
Nov 21, 2008
-   The grinder isn't working properly on my machine either. It worked great for about the first year and now the grinder doesn't start. So I open the machine, take out the grinder and twist the knob for the grinder a few times then I re-insert the grinder and push start. I usually have to do this at least 2 or 3 times before the grinder works again. Other times the grinder stops, then quits again before all of the coffee is out. When this happens I stop the machine and restart. I clean all of the parts after every use but I noticed that sometimes the grinder always has a little bit of water underneath no matter how long I allow it to dry. I like my coffee maker when it works correctly. -   cara76
Solution #1
posted on Dec 17, 2008
Somewhat Helpful)
ThaMp3Doctor
Rank: Guru
Rating: 86%, 4653 votes
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Was this helpful?
Yes
No
Solution #2
posted on Oct 24, 2009
Not Rated)
paulKB
Rank: Apprentice
Rating: 75%, 1 votes
Who is this mp3doctor anyway? This person must work for Cuisinart. Same posting for all of my searches. My grind and brew worked ok for the first year and then began having issues. Not grinding in any mode. If I stand over the unit and program it for several times it has worked. Seems to be an electrical issue that many other owners have.
Do not need the doctor to suggest that we should have better luck with buying another of the same. The odds are good for the game players not the consumers. We need solutions not marketing alternatives.
Our stainless Cuisinart looks great on the counter but thats about it. Had to take another morning trip to DDs. Tired of playing with this lemon!
PaulKB
Was this helpful?
Yes
No
Popular Solutions for Cuisinart Grind and Brew 10
Questions and Unsolved Problems for Cuisinart Grind and Brew 10
Do you recommend Cuisinart Grind and Brew 10 Cup Coffee Maker - Black and Stainless Steel?
Answer
Answer
The program light comes on immediately after plugging in machine and then blinks repeatedly. I can't... (More)
Answer
on off light stays on but does not brew. opened face, noticed moisture and slight burnt elec smell.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Coffee and... Experts
Top Small Appliance Repairmen
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
