Question about Microwave Ovens
Kitchenaid microwave KBMC140HSS0 blowing circuit breaker
I have a Kitchenaid over-the-range microwave KBMC140HSS0 that blows the circuit breaker every so often. Repair guys have replaced the fuse a few times and it works better for awhile and then does it again. Another repair guy came yesterday and said it can't be the fuse because when he used touchpad and pushed one button another would come on and one time he just walked by it and it came on. He thinks we need a new touchpad/keypad but he seems perplexed too. Any experience or advice with this?
3 Suggested Answers
SOURCE: JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
Posted on Oct 11, 2008
SOURCE: Microwave fuse blowing???
I laid out the stuff I wrote above in nice, neat lists and paragraphs, but this neanderthal editor/mail system jams it all together.
I think if I posted it as a solution instead of a clarification request, the format would be better preserved.
So here it is again hopefully in a better format.
Correct polarity is:
  • Wide blade = neutral = white wire = silver screw on outlet
  • Narrow blade = hot = black wire = brass screw on outlet
  • Grounding pin = ground = bare copper or green = green screw on outlet
With a multimeter set to Volts AC, the readings would be:
  • Between Wide & Narrow Blades = 120 Volts (nominal)
  • Between Narrow & Ground = 120 Volts (nominal)
  • Between Wide & Ground = 0 Volts or, a very small induced voltage reading
With multimeter set to ohms and breaker off:
  • Between Wide and Narrow = Infinite ohms (open circuit)
  • Between Wide and Ground = near 0 ohms (closed circtuit)
  • Between Narrow and Ground = Infinite ohms (open circuit)
My experience is that most homes will have at least a couple of circuits with reversed polarity. The black/brass white/silver schema is not a conclusive indication. For example, white wires are often used as black/hot wires -- by code these are supposed to be marked -- but 99% of the time they are not. Plus, it is very easy, when in production mode, to get these wires reversed somewhere in the circuit, whcih reverses everything downstream.
Reversed polarity is not a major issue unless the device plugged into the outlet uses its chasis/frame/cabinet as the neutral side of the circuit. In this case, the chasis becomes hot and can be very dangerous if there are grounding sources nearby. If the chasis is grounded as well as being used as neutral, reversed polarity can create a short (because hot is grounded).
Charlie
P.S. There is also a plug-in circuit tester available at hardware stores which will test for all the above.
Posted on Aug 30, 2009
Blowing breaker microwave intermittent
The microwave only draws a lot of current when cooking and on, you may have either a bad breaker or another item on that same circuit causing this, Fridge?
Dec 21, 2012 | Microwave Ovens
I have a kitchen aid microwave and have had it repaired at a autherized sevice center and it had a blown fuse. Now I have another fuse that has blown. It does it when the door opens and then blows leaving...
When the fuse blows in the microwave oven, it is often caused by a bad door switch. Sometimes food build up will clog it, or becomes defective, the only way to fix it is have it replaced.
Mar 30, 2011 | KitchenAid KCMS145J Microwave Oven
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air...
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Jul 30, 2010 | LG LMV1630 Convection/Microwave Oven
Microwave blows fuse when turn on
If it is blowing an internal fuse it could be a lot of things.
-short in the motor
-short in one of the other components
- gunk/dust could be causing a short
If it is your house circuit breaker/fuse then either the microwave draws too much current/amps for the circuit and you should try another circuit or you already have too many things/appliances plugged into the same circuit (not necessarily the same outlet) and need to unplug one or more of them so that the 'fuse' doesn't blow.
Kugellager
Nov 07, 2009 | Sharp R-1460 Microwave Oven
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Whirlpool microwave 2003 stopped working & inside light is on
The most likely cause is a blown fuse or a kicked circuit breaker. Look in the cabinet above the microwave and see if the microwave is plugged into the ou let in that cabinet. If it is plug a blow dryer or some other little appliance in to that same outlet to see if you have power there. If no power go to your electrical panel and either replace the fuse or turn the breaker off and then back on.
Mar 18, 2009 | Microwave Ovens
Keeps blowing breaker
Did you call Samsung's Service Division at 800-932-3837?
They may be able to give you a better number to call.
If you don't have them, you can download Samsung over the range microwave installation instructions here.
Please let us know what you find out.
Oct 22, 2008 | Emerson MW8987B/W Microwave Oven
Randomly blows circuit breaker while not running, only the clock is on.
Normally when the circuit breaker blows, it a bad door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | GE JES1358 Microwave Oven
Jenn-air model jmc7000
Can someone tell me where i can find fuse for microwave convection/grill oven 5kv 700ma There is a other no on the fuse TUV5m41GF
Aug 29, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
184 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
